Author Topic: Heater  (Read 27930 times)
Offline mikewb
Heater
« on: December 19, 2008, 02:49:14 pm »
Hey guys i need some ideas. I got a 82 swb chevy half ton. havent been able to get heat. Thought core was plugged soo i bought a brand new one and put it in yesterday still nothin. I thought might be the doors not opening and closing correct under the dash soo i took part off the front and moved then with my hands to see if there was hear coming out of there at all and theres not. The hoses are warm to touch but not hot. Cant figure out what else could be. Is it better to have the engine hose run off the intake or water pump?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Heater
« Reply #1 on: December 19, 2008, 03:24:08 pm »
are you sure you even have a thermostat on your engine?
Offline mikewb
Re: Heater
« Reply #2 on: December 19, 2008, 03:25:28 pm »
Yeah. I checked to see if there was one and its in there. but i dont know what size
Offline mikewb
Re: Heater
« Reply #3 on: December 19, 2008, 05:11:13 pm »
would a different thermostat let it get hotter?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Heater
« Reply #4 on: December 19, 2008, 05:16:51 pm »
the thermostadt might be stuck open.  Therefore not closing to allow engine to warm propertly, therefore, not having much heat/defrost.
Put another tstadt in there, they are cheap.  Ensure one hose going to heater core is hot, the return should not be as hot.
Offline mikewb
Re: Heater
« Reply #5 on: December 19, 2008, 05:18:56 pm »
Both hoses are just barely hot. I can hold them without any problem
Re: Heater
« Reply #6 on: December 19, 2008, 06:36:19 pm »
Put a 195° T-stat in it
Offline mikewb
Re: Heater
« Reply #7 on: December 19, 2008, 08:27:58 pm »
is that bigger then normal? whats the biggest one?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Heater
« Reply #8 on: December 19, 2008, 08:57:23 pm »
I wouldn't describe it as "bigger" but normal tstadt is 180.   a 195 will bump the temp up prior to opening up. A new tstadt will keep the temp where it supposed to be.  When you take the old one out, note the spring on it and if it is compressed, that keeps it open and the antifreeze is just free flowing no matter the temp.
Re: Heater
« Reply #9 on: December 20, 2008, 07:52:40 am »
195° is factory.
Offline mikewb
Re: Heater
« Reply #10 on: December 20, 2008, 12:51:26 pm »
That the hottest one you can get?
Re: Heater
« Reply #11 on: December 20, 2008, 01:33:27 pm »
No but you don't need or want hotter than that. Just replace yours. I replace mine every year.
Offline mikewb
Re: Heater
« Reply #12 on: December 22, 2008, 05:50:05 pm »
Ok boys, I got a new thermostat and heater core. And still no heat. What else might it be? It doesnt even blow warm air.
Re: Heater
« Reply #13 on: December 22, 2008, 07:12:11 pm »
Are the hoses to the heater core hot?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Heater
« Reply #14 on: December 22, 2008, 08:39:03 pm »
I am assuming you did this after replacing the tstadt, but, ensure your antifreeze level in radiator is good.  That is the blood of the heater system.
