Author Topic: Air filter idea  (Read 7240 times)
Offline team39763
Air filter idea
« on: December 23, 2008, 05:39:28 pm »
I decided I wanted to keep the stock look as far as outside appearance.  I was thinking I could snag the stock air cleaner assembly off my 454 dually and route the snorkel to a opening(cut by me) in the firewall(the upper part that meets the wiper cowl).  I figured I could throw in a nice K&N filter and it would be better than my open air filter sucking in all the hot air off the motor.  +Plus it'll look more like your average smallblock chevy.  What do you guys think?  Will a 3" snorkel/opening feed this combo?
Offline SUX2BU99
Re: Air filter idea
« Reply #1 on: December 23, 2008, 06:39:27 pm »
That's how some of the factory and NASCAR cowl induction worked. The Z11 409 motors come to mind. I have an article with a 63 Z11 in it and it has that kind of induction. If you don't mind cutting your firewall, then go for it! A short run of 3" should be fine.
Offline team39763
Re: Air filter idea
« Reply #2 on: December 23, 2008, 08:14:41 pm »
I had originally planned to use an actual nascar air cleaner, but those go for around $90+ on ebay.  Hopefully this works out good then.  I'm gonna go try it in a minute.
Re: Air filter idea
« Reply #3 on: December 23, 2008, 09:29:25 pm »
This has been discussed already.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7203.0
Spectre also makes a dual inlet air cleaner that will bolt right in
Offline team39763
Re: Air filter idea
« Reply #4 on: December 23, 2008, 09:54:03 pm »
I must have overlooked that one.  I remember it now, there were some good ideas mentioned.  Anyway, mine looks like it might work with a little trimming and an extra hose to run to the firewall.  I'll post up pics when I finish it this weekend.
Re: Air filter idea
« Reply #5 on: December 24, 2008, 12:00:00 am »
with my impala i ran a home made fwi out of PVC pipe into the fender and inside the fender had a a flat cone k&n filter. wish i could find pics
Offline blackRose18
Re: Air filter idea
« Reply #6 on: May 21, 2009, 10:46:16 pm »
I think it was it could snag the stock air cleaner assembly off my 454 dually and route the snorkel to a opening(cut by me) in the firewall(the upper part that meets the wiper cowl).
_________________
Basement Dehumidifier
Offline eventhorizon66
Re: Air filter idea
« Reply #7 on: May 21, 2009, 11:59:29 pm »
I think you threw out any chance of a "stock look" out when you dropped in a carb'd LSX motor. :D
'85 C10 SWB 350 700R4 TKO600
