Author Topic: Unknown module under the dash  (Read 5555 times)
Offline Psycho_Bob
« on: December 23, 2008, 11:37:39 pm »
I was installing an AM/FM/CB/Cassette radio out of an 83 Eldorado in my '81 C-10  In doing this I got to spend plenty of on my head time looking under the dash.  I found a module mounted under the dash that I am not sure about.  It is a box mounted upright right above the accelerator pedal.  It appears to go to the distributor harness, but some of the wires to the distributor have been cut and looped on the distributor side.  Can anybody tell me what this module is and why the modification has been made to the wiring on it.
Thanks
Re: Unknown module under the dash
« Reply #1 on: December 23, 2008, 11:45:23 pm »
the only thing i can think of is a tach
« Reply #2 on: December 24, 2008, 08:20:26 am »
Probably the ESC controller which retatrds the ignition timing based on input from the knock sensor. Someone probably bypassed it.
Offline Psycho_Bob
« Reply #3 on: December 25, 2008, 03:05:18 pm »
Would it be worth re-enabling it and would it gain me any gas economy?  The previous owner has rigged up everything else in this truck for no good reason.  I have seen several other posts where people already have them disabled, but never explained why.   The compression is down enough on my truck that I don't have to worry about spark knock  with the corn gas around here.
« Reply #4 on: December 25, 2008, 03:56:05 pm »
I wouldn't bother. If you're going to upgrade the ignition system that's a good idea but the esc ignitions are junk.
Offline bigkountry
« Reply #5 on: December 25, 2008, 04:23:02 pm »
I removed the ESC form my 81 K10 long ago.
« Reply #6 on: December 27, 2008, 10:13:09 pm »
If someone bypassed it the only think you will gain is aggrivation.  Most all of them were bypassed.  Even dealerships bypassed them.
