Author Topic: DOOR JAMB WIRING GROMMETS NEEDED!  (Read 8418 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
« on: December 28, 2008, 10:10:24 pm »
I NEED A SET OF DOOR JAMB GROMMETS FOR MY 78 SILVERADO. I AM INSTALLING SPEAKERS IN MY DOORS AND I WOULD LIKE TO USE CORRECT GM GROMMETS TOO RUN THE WIRING. ANY HELP WOULD BE GREAT AND INSTALLATION TIPS ARE GREATLY APPRECIATED.
THANKS,
kfoz
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Offline Dragon
Re: DOOR JAMB WIRING GROMMETS NEEDED!
« Reply #1 on: December 28, 2008, 10:55:01 pm »
Well GM actually used rubber sleeves whenever they ran wiring through our doors, but the grommets that they used in other areas of the body, should still be available through your local Dealership... Just ask for whatever size you want, but the Secret most don't know, is that the sheetmetal grommets can be found at your Local Larger well stocked Hardware Store(Lowes/Home Depot/Etc)....  A single grommet bought at the Hardware Store, will generally be not even half the price of what the Stealerships will charge you.....
If you are really set on the High Mark Up of a "OEM" Grommet that isn't available at your Stealership. then I would check with Year One/Etc (Chris might have some of the affordable ones though) .....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline kfoz
« Reply #2 on: December 29, 2008, 05:03:26 pm »
Thanks! I should have said " DOOR JAMB WIRING BOOTS" not grommets!  What I need is the DOOR JAMB WIRING BOOTS!
Thanks again,
kfoz
'73 C20 4 Speed 2WD
Offline Igosplut
« Reply #3 on: December 29, 2008, 05:21:22 pm »
The GM term for the is "conduit" and they were 60.00$ from GM ten yrs ago (they came with two medal flanges). might still be in the book, if you need the part No. I can look it up in my receipts....
« Reply #4 on: December 29, 2008, 06:24:05 pm »
Check with GM for a 88-91 R/V Truck.  I can check for you.  I can probably get it if they have it, but it will be next week until I can let you know.
Offline kfoz
« Reply #5 on: December 29, 2008, 06:54:06 pm »
Thanks everyone. Let me know what they will cost me please.
kfoz
'73 C20 4 Speed 2WD
Offline kfoz
DOOR JAMB WIRING CONDUIT NEEDED!
« Reply #6 on: January 02, 2009, 06:52:46 pm »
I CHECKED AT A DEALERSHIP AND NOTHING IS AVAILABLE. IF SOMEONE KNOWS OF SOME DONER ONES, PLEASE CONTACT ME.
THANK YOU,
kfoz
'73 C20 4 Speed 2WD
