Author Topic: Proper way to back flush cooling sys?  (Read 5018 times)
Offline Dave Kay
« on: January 01, 2009, 03:12:24 pm »
Will be installing a new radiator this weekend on my '86 GMC SB and would like to back flush the block before installing new unit. My idea is that I don't want any rust or sediments to be pushed into the NEW radiator. Have the Prestone kit w/garden hose adaptor and the instructions make no mention about removing the thermostat before back flush... is this nesassary?
Offline TexasRed
Re: Proper way to back flush cooling sys?
« Reply #1 on: January 01, 2009, 04:45:32 pm »
I'd remove the thermostat anyway and replace it. . . .unless it's like real new.
Offline VeeTwin60
« Reply #2 on: February 05, 2010, 04:54:51 pm »
Is there any other thoughts on this?  I'm replacing my radiator and thermostat this weekend and I have the same flush kit as the guy above.  I've never done this before, so any pointers/tips/help would be appreciated.
1986 C-10 1/2 TON 2WD SWB
« Reply #3 on: February 05, 2010, 07:51:50 pm »
The way I do it is with a machine I have but since you don't have one I would suggest you run a good cleaner in the system first. Run it to operating and for at least 15 minutes after the T-stat opens. Drain the system when it's hotter (no pressure and be careful) Remove the engine block drain plugs (sometimes you need to stick a pocket screwdriver in the hole due to scale build up to allow it to drain. Flush out the heater core and passages with a garden hose. Once you refill the system add a conditioner. It helps prevent oxidation, scale and cavitation.
* fixed typo
« Last Edit: February 06, 2010, 12:00:11 am by VileZambonie »
Offline VeeTwin60
« Reply #4 on: February 05, 2010, 08:16:25 pm »
Thanks.  Sounds like a lot of work, but I want to do it right.
Offline VeeTwin60
« Reply #5 on: February 07, 2010, 12:45:54 pm »
That was easier than I thought.  Messy... but easy.  Thanks again.
