Author Topic: high idle switch  (Read 3467 times)
Offline maximus5541
high idle switch
« on: January 05, 2009, 12:46:15 pm »
On my 83 swb, the previous owner had swapped in a edle. carb and intake, and as a result didnt hook up the high idle switch, so now when i run the a/c, it drags the rpms down to low. So is there a provision on a edle. carb to hook up the high idle connection?
1983 Chevy C10 SWB, 2wd, 350/350
1987 Chevy R20 LWB, 2wd, 305/400
1983 Chevy C10 LWB, 2wd, 305/700r4
Re: high idle switch
« Reply #1 on: January 05, 2009, 03:24:31 pm »
You can use an oem one with the bracket adapter or just fabricate one.
http://www.edelbrock.com/automotive_new/misc/tech_center/install/1000/1997.pdf
