Author Topic: 1987 chevy block stats? need to know for compatibility  (Read 4379 times)
Offline Thowell
« on: January 08, 2009, 01:37:53 am »
i am wanting to either buy an extra block or go for the extensive rebuild. and so really i was wanting to know if the four bolt main blocks would work? also the 2.02 heads. i ask because those are the ones that im seeing alot of on craigslist here in kansas city. so just give me your thoughts on how i should go about it. also i was wanting to know whats better. to buy a posi carrier or a locker? i ask because its better to learn before hand than to go pay and have it done and then realize i got suckered. thanks for the advice
Re: 1987 chevy block stats? need to know for compatibility
« Reply #1 on: January 08, 2009, 04:52:38 am »
4 bolt mains are for heavy duty use and will work fine.
Personally I prefer a lsd over a locker.
« Reply #2 on: January 08, 2009, 05:20:16 pm »
For a street driven vehicle, 2 bolts are fine and 4 bolts most people overprice
I don't like lockers unless it is on a Jeep for offroad.
Offline Thowell
« Reply #3 on: January 09, 2009, 08:42:35 pm »
well i mean wouldnt a locker be technically true posi? and should i go buy a new locker or posi carrier or search for someone with a used one?
« Reply #4 on: January 12, 2009, 04:52:57 pm »
A Posi is what GM called their limited slip differentials.  A locker locks both axles, so no they are different.
