Author Topic: Alternator  (Read 5948 times)
Alternator
« on: January 08, 2009, 10:56:36 am »
Anyone know a parts place that carries a quality high amp alternator, 130 /140 amp? All my parts places around here can only get a 94 amp one for my 86 K30!
Offline joesgarage71
  • Wrench
Re: Alternator
« Reply #1 on: January 08, 2009, 11:02:10 am »
 Have you thought about a CS install?
Offline Stewart G Griffin
Re: Alternator
« Reply #2 on: January 08, 2009, 11:07:55 am »
i know napa can get Bosch alternators.  And jeg's/summit have MSD alternators which should supply your 130/140 amp requirements.  They're high dollar, but probably worth it.
Re: Alternator
« Reply #3 on: January 08, 2009, 11:22:06 am »
Have a place that can rebuild mine to 135 Amps for about $100. another place that said to upgrade to I think he said CS, ( Was up till 4:00 AM plowing, & have talked to about 20 parts stores etc. ) He said it would be a one wire set up, and go by RPMs. $175!
Re: Alternator
« Reply #4 on: January 08, 2009, 11:57:00 am »
I would just convert to a CS alternator also.
  • Wrench
Re: Alternator
« Reply #5 on: January 08, 2009, 12:35:08 pm »
 Here is one of many write ups.
http://www.novaresource.org/alternator.htm
 Harness adapter.
http://i76.photobucket.com/albums/j23/jc94vtc/1987%20Monte%20Carlo/CS144%20DIY/cssiharness.jpg
 Delco # 8078 and gm # 12102921 if you have a volt gauge
 Delco #8077 and GM # 12083462 if you have a idiot light
« Last Edit: January 08, 2009, 12:44:09 pm by joesgarage71 »
Re: Alternator
« Reply #6 on: January 08, 2009, 09:58:18 pm »
Dropped the old one off. It would have been about $150 with the three wire CS alternator. He looked at mine said around $80 to rebuild it to 140 amps. So I opted for that route. He said the CS alternators he would recommend would require mount modification too.
