Author Topic: tv cable adjustment help  (Read 13605 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: January 08, 2009, 01:28:07 pm »
My tv cable just simply will not self adjust on my truck.
carb is a holley 600
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D700202&N=700+115&autoview=sku with this geometry corrector
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D700202&N=700+115&autoview=sku and this throttle bracket
I put a new detent cable on it and no change. I push the button and push the cable all the way towards the firewall and I don't feel any resistance and it does not self adjust. Even putting it at wot at the carb doesn't make it self adjust.
Oh and the intake manifold is aftermarket. What am I doing wrong?
« Last Edit: January 08, 2009, 01:30:41 pm by dumbucket1 »
Offline eventhorizon66
Re: tv cable adjustment help
« Reply #1 on: January 08, 2009, 02:57:04 pm »
If the cable does not self adjust when you pull the throttle to WOT, it is too long.  I have seen several different lengths offered.  You should feel tension (good tension) when you depress the button and pull the cable all the way back towards the firewall.  I wish I could be more helpful as far as pointing you in the direction of the correct length, but I'm not sure about that.  I think it's supposed to be the 40" version.
But you are on the right track with that geometry corrector, that is simply a cheaper version of the Sonnax bracket.
« Last Edit: January 08, 2009, 03:00:49 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: January 08, 2009, 03:03:16 pm »
I don't know. I bought the new cable from oreilly auto and it's the exact same length as the old one. Maybe with this set up all the way in is where its supposed to be. I won't actually be able to test drive the truck for awhile.
« Reply #3 on: January 08, 2009, 03:10:53 pm »
If it's not the length of the cable itself, I'd say the bracket is mounted too close to the throttle linkage.  I definitely would not drive the truck until you get that cable to self adjust.  Don't just assume that all the way in is where it's supposed to be.
To confirm the proper TV operation, you need to pull your trans pan and see if the TV plunger is being pushed all the way down in its bore when the carb is pulled to WOT.  I bet it's not.
BTW the second link in your first post is just a duplicate of the first link.  What bracket are you using?
« Last Edit: January 08, 2009, 03:14:19 pm by eventhorizon66 »
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #4 on: January 08, 2009, 03:48:28 pm »
« Reply #5 on: January 08, 2009, 03:50:24 pm »
What trans do you have? Are you sure it's connected to the TV valve in the trans?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #6 on: January 08, 2009, 03:52:12 pm »
700r4 and yes its connected for sure. If you take the cable off the linkage and pull it by hand you can feel it get pulled back in.
« Reply #7 on: January 08, 2009, 03:53:53 pm »
Is there any resistance in the cable when it's attached to the linkage if you pull on it?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #8 on: January 08, 2009, 03:59:10 pm »
I had to go out and check. There does seem to be some slack in it but not much. So chances are the stock length cable is too long with all these aftermarket parts?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #9 on: January 08, 2009, 04:09:52 pm »
and before I changed to an aftermarket intake, carb, etc everything worked fine
« Reply #10 on: January 08, 2009, 04:13:24 pm »
How does it shift with the plunger all the way toward the firewall?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #11 on: January 08, 2009, 04:22:32 pm »
I won't be able to test drive it for awhile
Offline HAULIN IT
« Reply #12 on: January 08, 2009, 05:51:42 pm »
What I have found (with Holley carbs) is the carb itself is harder to open, as in overcomming the accelerator pump, ect. This makes the round rod that the pedal is made out of flex a little, also the bracket you got to mount the cable is likely flexing also, all the ones I've seen for the Holley are cheesy except the Bowtie Overdrive set-up. Have someone work the pedal & watch the bracket, then open the carb by hand & see if it clicks. What should work for you (but not the correct way, of coarse) is to work it out under the hood to get your adjustment, but pull the cable off of the carb once you think it's set & have someone floor it inside, then compare where the TV cable (once pulled) lines up with the pin on the carb & adjust if needed another click or so. My thought is the flexing is just enough to not let the cable "snap" to the next groove, so it just sits there not adjusted. Check it out & report back! Lorne
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #13 on: January 08, 2009, 10:56:23 pm »
the brackets are actually very thick and stiff. no flexing at all. Almost seems like the cable is too long now. Possibly a bad cable straight from oreilly's? but then again the old cable was fine when the stock intake and quadrajet was on the motor.
Offline HAULIN IT
« Reply #14 on: January 09, 2009, 08:56:00 am »
 That's the bracket I'm familiar with...A new one I've seen, but haven't tried yet is the one that goes to both Left carb studs.
 Does your pedal seem stiffer to push down with the Holley?
 I just noticed in your first post that you did try manually working the carb...so at this point does the TV cable limit the carb from going to full throttle because it won't adjust? Pull the cable off the carb, open the carb & pull the cable to varify that distance. Can you feel slight resistance AS SOON as you start to pull the cable or is there slack at the beginning?
 The moral of the story....The thing worked with the Q-jet  ;) Let us know what you find, Lorne
