Author Topic: LOWER CONTROL ARMS --- VS. --- DROP SPRINDLES  (Read 8882 times)
Offline okuma
« on: January 10, 2009, 02:57:03 pm »
I plan on installing air suspension in the near future to my truck.
My question is  what would be a better choice and why if I install  3'' lower control arms    or    if i install 3''drop spindles.
 thnxs guys !
Offline three8six
Re: LOWER CONTROL ARMS --- VS. --- DROP SPRINDLES
« Reply #1 on: January 10, 2009, 05:20:49 pm »
I would suggest the spindles even though to run the factorys you have to modify the LCA's. They will keep you're truck in alignment. The LCA's are as bad as the lowering coil springs from what I've seen with keeping you're truck in alignment.
« Reply #2 on: January 12, 2009, 04:33:59 pm »
they are both good.  I have both on current vehicles.  I haven't had alignment problems with either.  Generally LCA's only go down 2.5" where spindles can be had at 3".
Offline okuma
« Reply #3 on: January 13, 2009, 11:29:36 pm »
is it true?   i have heard that with spindles your front tires are further out . ???
« Reply #4 on: January 13, 2009, 11:58:54 pm »
Spindles will increase the track width by about .25" per side, but if you have custom wheels with custom backspacing it isn't going to matter.
I just re-read your post and if I were going airbags, I would do the spindles.  Someone posted that CPP's spindles don't modify the track width.
Offline ms4972
« Reply #5 on: January 18, 2009, 08:32:55 pm »
Drop spindles are definately the way to go.  Better geometry and suspension travel.
It's true about most drop spindles widening your track.  I've seen some that push you out as much as 3/4" on each side.  I just put a set of the CPP spindles on my '75 and it narrowed my track width.  I can finally make a u-turn.
Offline okuma
« Reply #6 on: January 24, 2009, 06:16:42 am »
THANKS guys , where can i get myself cpp spindles what are they 3" drop ?
Offline okuma
« Reply #8 on: February 27, 2009, 12:20:51 pm »
i contacted these guys fromm cpp but if i go the cpp route ..... i would need to replace to 1.25" rotors and calipers because i have 1" in place right now
Offline Chevalade
« Reply #9 on: March 20, 2009, 04:52:50 pm »
_6087DBK - Bracket kit to work with factory disc brakes and CPP Modular Spindles
Ryan
