Author Topic: 91 5.7L questions  (Read 5669 times)
91 5.7L questions
« on: January 10, 2009, 08:54:33 pm »
Can I modify the intake of a 5.7L to work with a carb?   The engine I pulled from my 91 parts truck has a block off plate for the fuel pump, were they typically machined to go either way or was it a way to use up the old block inventory?  I would like to try playing with a 1 bbl fish carb with this engine.
Re: 91 5.7L questions
« Reply #1 on: January 10, 2009, 08:58:11 pm »
What do you mean modify the intake?  ???
If it has the block off plate you can use a mechanical pump if that's what you are asking.
« Reply #2 on: January 10, 2009, 09:02:31 pm »
Use the intake by machining an adaptor plate for the fish carb?
Offline HAULIN IT
« Reply #3 on: January 10, 2009, 09:08:01 pm »
What is a fish carb? Is it flat on the bottom?
« Reply #4 on: January 10, 2009, 09:11:19 pm »
Offline HAULIN IT
« Reply #5 on: January 10, 2009, 09:26:01 pm »
Ok, If I had heard of those, I forgot I guess. I do remember hearing/reading about Fireball Roberts on some of the old Nascar shows/books. Can they be bought today?  Zieg, in the "pictures" part of the site shows what looks like a Fish to Q-jet adapter...Looks to me a flat plate could work though. Thanks, Lorne
Offline joesgarage71
  • Wrench
« Reply #6 on: January 10, 2009, 09:59:57 pm »
  I have seen some earlier 90's blocks have the fuel pump boss cast in the side but no hole machined for the fuel pump rod. If yours has a plate the rod hole might be there too.
 Steve
