Author Topic: easy way to install turn signal switch  (Read 7725 times)
Offline 1badazz84
« on: January 11, 2009, 02:40:59 pm »
What's the easy way to install a turn signal switch by taking the column apart or is there a easy way to do it.
Offline jefferias
Re: easy way to install turn signal switch
« Reply #1 on: January 11, 2009, 03:43:30 pm »
haha  i tried to do mine and just got agitated and broke some stuff.  got a whole column from a wrecker for $20 and just replaced whole unit!  that was easier to me most defnitely
« Reply #2 on: January 11, 2009, 06:41:37 pm »
yes it's easy if that's what you were asking. Remove the wheel, the lockplate, hazard button, signal stalk, canceling cam, 3 screws, and the connector. It might be easier if you loosen the column a little bit but it isn't necessary. Tie some mechanics wire around the connector and snake it out. Wrap the mechanics wire around the new one and put it in.
Offline 1badazz84
« Reply #3 on: January 16, 2009, 07:17:13 pm »
thanks for the heads up i think i could do it without getting  >:(.
