Author Topic: 73-80 body side molding  (Read 11457 times)
Offline got2haul
« on: January 12, 2009, 11:29:49 am »
How is the upper and lower molding attached to the body for these years?  Are brackets used?  Holes punched in the metal, the bracket screwed through the hole and the molding snapped onto the bracket?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Re: 73-80 body side molding
« Reply #1 on: January 12, 2009, 11:31:57 am »
There are clips that attach to the body. I'm not sure about the aftermarket replacement trim moulding though. Someone just redid theirs with new trim I believe.
« Reply #2 on: January 12, 2009, 01:35:53 pm »
They attach the same way. ccz145a just got some....
Offline ccz145a
« Reply #3 on: January 12, 2009, 03:30:17 pm »
Quote
Yeah, clips are the same as stock. I have not put any on yet, just recently got the word that my job will be moving me to Houston.
Fixing up the house is my latest project, the truck will continue as soon as I am relocated.
Offline HAULIN IT
« Reply #4 on: January 12, 2009, 05:18:17 pm »
There are several different clips used originally (depending on what panel the molding is on). Basically, the corners/ends had a stud type plate that slid into the molding & a speednut went on from the back (the fenders & cab corners used only these). The other areas in between those (length of the bedsides & doors) had square plastic clips with Two sided tape. The tailgates used another clip on some years that was like a "V" & slid on the molding & pushed in a hole on the ends. It seems to me that some fenders had a Phillips screw at the back, next to the door.
 The way I've set-up to drill new panels is this...Tape/have someone hold the moldings in place, draw around them on both sides with a pencil, then remove the moldings, split the width in half & that's your drill line. On the fenders, there are access holes in the inner panel...be sure to line up your holes accordingly. Lay it all out, drill, then paint. If your Two toning, the holes become your guide as to where to tape. Have Fun! Lorne
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: January 13, 2009, 01:06:07 am »
Here's an article about some of it:
http://www.classictrucks.com/tech/0606cl_1975_chevy_c10_trim_install/index.html
Some pics of mounting holes:
« Last Edit: January 13, 2009, 01:22:10 am by 78 Chevyrado »
