Author Topic: th350 is not shifting??? Help please  (Read 6925 times)
Offline Fish
« on: January 15, 2009, 06:45:25 pm »
Hi guys & gals,
I just drove my 86 SB home for the first time since putting the moter and tranny in and it would not shift out of first.  The vaccum is hooked up to the manifold vaccum.  I don't know what the issue is.  Fluid is good.  It is a fresh rebuild, so there should be no issues with the tranny, but there is.  Anyone have any ideas?  Thanks in advance,
Fish
Re: th350 is not shifting??? Help please
« Reply #1 on: January 15, 2009, 07:12:18 pm »
Is the detent cable hooked up? Is the governor gear ok?
Offline Fish
« Reply #2 on: January 15, 2009, 07:22:26 pm »
Yes to both.  The only thing that I think it could be is the connector in the vaccum hose isnt letting enough vaccum get to the tranny, do you think this could be it?
« Reply #3 on: January 15, 2009, 07:26:40 pm »
pull the hose off the modulator with the engine running. Is there vacuum? If the detent cable is adjusted correctly and the governor valve is good you'll have to give more detail on what you did to the transmission.
Offline Jon87V20
« Reply #4 on: January 15, 2009, 07:34:15 pm »
Which port do you have the modulator getting its vacuum from?
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Offline Fish
« Reply #5 on: January 15, 2009, 07:35:45 pm »
Its getting the vaccum from the manifold
Offline roadrage41
« Reply #6 on: January 16, 2009, 07:27:08 am »
you have a shift kit installed during the rebuild?
Offline Fish
« Reply #7 on: January 18, 2009, 03:53:18 am »
Yes
Offline joesgarage71
  • Wrench
« Reply #8 on: January 18, 2009, 10:44:24 am »
I'd be takeng it back to the rebuilder.
Offline DnStClr
« Reply #9 on: January 19, 2009, 11:56:51 am »
Could it be that the modulator might have to be swapped with a modulator to match the shift kit?
Don
87 Chevy Silverado
  • Wrench
« Reply #10 on: January 19, 2009, 01:16:06 pm »
Some are adjustable, sm screw in the vacuum port.
