Author Topic: Methanol/Water injection?  (Read 6237 times)
Offline Rib Tickler
« on: January 17, 2009, 09:50:36 am »
 :oAny of you guys tryed these things? do they do what they are supposed to? I seen them at Jegs, can`t remember the link, I`ll see if I can find it.
Offline Chevalade
Re: Methanol/Water injection?
« Reply #1 on: January 17, 2009, 10:38:14 am »
They do work really well. But no for use on lower compression motors unless they are boosted.
Offline joesgarage71
  • Wrench
« Reply #2 on: January 18, 2009, 09:18:13 pm »
 I'd like to get a kit for my 04 after things pick up at work. Don't need to be boosted will work on reg gas truck.
http://www.aquatune.com/index.asp
http://www.coolingmist.com/pagedisplay.aspx?feature_key=gasvehicles
« Last Edit: January 18, 2009, 09:30:16 pm by joesgarage71 »
Offline 85MudMonster
« Reply #3 on: January 18, 2009, 10:24:13 pm »
swo it injects water into your engine, or methanol, or both?
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline Rib Tickler
« Reply #4 on: January 18, 2009, 11:05:40 pm »
yes...I`ve seen that aquatune one...and thats the one I think I`m gonna try. Hopefully at the end of this month I`ll order one!
« Reply #5 on: January 18, 2009, 11:07:45 pm »
Water injection was originally used to help quench high compression engines.
  • Wrench
« Reply #6 on: January 19, 2009, 09:02:56 am »
  ..., gave our fly boys a extra boost of power during take off in the 1940's
« Reply #7 on: January 19, 2009, 12:21:56 pm »
My brother uses it on his turbo truck.  He/(we) sell snowperformance pieces.
Offline mattevandavis
« Reply #8 on: January 25, 2009, 08:34:34 pm »
Great on boosted apps.  it is marginal on non boosted apps.  the meth burns cooler than gas .  turbos burn hot with high boost and high advance so it helps advance timing with out det.
