Author Topic: oil leak  (Read 4757 times)
Offline nikesb1111
oil leak
« on: January 26, 2009, 01:24:20 pm »
so i have an oil leak in my 86 k10 coming from around the inspection plate, its a 350 with a 700r4. Its leaking motor oil but i cant really tell exactly where its coming from but its all over that area. I was thinking maybe the rear main seal. Any ideas? also i have holley 600 four barrel and whenever i take the truck out of gear the fast idle kicks on, any ideas?
« Last Edit: January 26, 2009, 01:28:06 pm by nikesb1111 »
Re: oil leak
« Reply #1 on: January 26, 2009, 01:29:24 pm »
pull the cover and spray it off to find the leak.
Offline nikesb1111
Re: oil leak
« Reply #2 on: January 26, 2009, 01:56:53 pm »
i pulled the cover and everythings dry. Heres a couple pics i snapped.
Offline eventhorizon66
Re: oil leak
« Reply #3 on: January 26, 2009, 02:03:18 pm »
It could also be a leak at the rear of the intake manifold, where it meets the block.
'85 C10 SWB 350 700R4 TKO600
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: oil leak
« Reply #4 on: January 26, 2009, 02:16:22 pm »
or out of the oil pressure sending unit hole, or out of the distributor hole
Offline 84chevysilverado
Re: oil leak
« Reply #5 on: January 26, 2009, 03:09:06 pm »
we had the same problem at my work with one of the work trucks. what we did is GM sells some kinda seal renewer that you put into your motor oil  wich swells up the seals and makes them not leak anymore. worked really well still hasnt leaked. but this is also just a quick fix and only works if its leaking around the seals.hope that helps
Re: oil leak
« Reply #6 on: January 26, 2009, 08:27:10 pm »
your oil pan looks rotted amongst the other leaks.
