Author Topic: lockers  (Read 7568 times)
Offline murraygmc
  • 85 gmc 4x4
lockers
« on: January 27, 2009, 11:06:27 am »
i have maby a hard question to ancer.  iv got a 85 gmc with the V6 4 speed ( L,1,2,3,r ) 4x4 what rearend do i have ?  the reason im asking is im looking in to a rear locker and dont know what to get ?   P.S. im going to upgrade to a 350 soon
85 gmc high serria 4x4
Re: lockers
« Reply #1 on: January 27, 2009, 12:04:00 pm »
If it's the stock rear end it's probably a GM 10 bolt. 3.08:1 was a common ratio but the only way to tell for sure is to pop the meatball cover off and check.
Offline murraygmc
  • 85 gmc 4x4
Re: lockers
« Reply #2 on: January 27, 2009, 01:29:22 pm »
ok im kinda slow lol  how the heck do you check   ???
Re: lockers
« Reply #3 on: January 27, 2009, 01:42:27 pm »
All 83-87(91) 1/2T trucks came with 10bolts from the factory.  To tell there are 10 bolts on the inspection cover.
To tell what ratio it is, pull the cover and look for the tooth count stamping on the ring gear
To find out if it is a factory limited slip, there will be a rachet mechanism and a spring on either side of the carrier.
Offline murraygmc
  • 85 gmc 4x4
Re: lockers
« Reply #4 on: January 27, 2009, 02:01:46 pm »
ok so how do i come up with that no. ?   what dose it mean if i bought a locker do i got to buy the guts in the rearend too thanks
Re: lockers
« Reply #5 on: January 27, 2009, 04:27:11 pm »
How to come up with what number?  The ratio?
If you buy a locker and like the current ratio, you only need the locker and associated parts.  (I would replace the bearings/seals)
If you are buying a drop in locker that replaces the spider gears, you only need to pull the crosspin and replace the guts of the carrirer.
Offline murraygmc
  • 85 gmc 4x4
Re: lockers
« Reply #6 on: January 28, 2009, 10:48:24 am »
ya the raito no. iv got no clue what kind of locker i want the cheepest probly .   any ideas on what kin of locker to buy im just going to mainly need it 4 snow geting to fire wood (that could b any whare) slight to modret trail riding
« Last Edit: January 28, 2009, 11:07:50 am by murraygmc »
Offline Fishtail8
Re: lockers
« Reply #7 on: January 28, 2009, 11:00:17 am »
You could also try checking RPO codes in the glovebox, as long as no one's switched diffs over time.  A trick that works for approximating gear ratio without pulling the cover is....
1- Make a chalk mark on the side of the driveshaft, and the 12 oclock position on the driver's side tire.
2- Jack the rear end up so both tires are off the ground.
3- With a friends help, rotate both tires at the same time, forward, and at close to the same speed one complete revolution.
4- While making the one complete revolution, count how many times the mark on the driveshaft goes by it's original starting point.
It's not rocket science, or as good as popping the cover. I've used this trick a couple of times, and it gives you a good idea of what you could have. I usually put the chalk mark on the side of the driveshaft facing the tire I marked. Try it and see if it works.
As far as checking for a locker or limited slip in it, rpo's and /or pulling the cover are the only way.  If it's got the G80 rpo it should be a gov-lock.
Re: lockers
« Reply #8 on: January 28, 2009, 11:53:43 am »
The G80 = A gov-loc is only applicable for late 70's and a beyond.  The early trucks had G80's but had a clutch type limited slip.
If you want to go on the cheap (as in all around) look at lock-rite or ez locker.  They replace the spider gears and you don't have to take the rearend down.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: lockers
« Reply #9 on: January 28, 2009, 12:20:21 pm »
Just pull the cover, it doesn't take long and it probably needs an oil change anyway ;D
Gear ratio= (number of teeth on ring gear) divided by (number of teeth on pinion gear).
Offline KoolerSL2
  • Chevy / Ford: A house Divided
Re: lockers
« Reply #10 on: January 28, 2009, 05:41:57 pm »
or another way would be to find the code on the pass side axle tube and call your local dealer.
they would be able to tell you what gear and such as long as the rear end is the original one.
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
