Author Topic: Removing Leafs  (Read 11358 times)
Offline Jay2D2
Removing Leafs
« on: January 28, 2009, 10:05:03 am »
Hey guys I have a 1982 K25 4x4 and I was wondering if it is possible to remove some of the leafs in the back.. maybe also in the in the front... Im starting to strip and rebuild this truck soon and since I dont plan on really working like a 3/4 ton I was wondering if I could soften the ride a little.  I believe it has 8 leafs in the rear, not sure about the front.  It has the quad shocks in the front from factory and the rear diff is 14 bolt 10.5 ring gear, not sure about the front.. let me know what you think.
Also to note I would like to retain stock or near stock ride height, ie I dont plan on raising or lowering the truck but id the removing springs changes the heaight i will be ok
Re: Removing Leafs
« Reply #1 on: January 28, 2009, 11:57:38 am »
If you remove leafs the truck is going to go down.
Offline Jay2D2
Re: Removing Leafs
« Reply #2 on: January 28, 2009, 02:14:18 pm »
Yeah I figured that but I was more concerned with clearance issues and if there was a ratio from back to front of the amount of springs to remove to retain an even height.. like 2 rear leafs for one front leaf?
Offline joesgarage71
  • Wrench
Re: Removing Leafs
« Reply #3 on: January 28, 2009, 03:57:20 pm »
 Just remove the overload from the rear. It will make a diff in the ride Qty. take it for a ride, if it still too rough take more out.
« Last Edit: January 28, 2009, 03:59:30 pm by joesgarage71 »
Offline 75??? franken-trunk
Re: Removing Leafs
« Reply #4 on: March 16, 2009, 12:35:18 am »
i also need help in this subject..... i have a set of used front lift springs. but i think they are 8" and i want 6" one but im broke and i can't find any used, could i remove some leafs to lower it and help the ride... and if so how do i and how many do you think should be removed (theres 6 leafs total per spring)
Jack'em High
Fat chicks can't climb
Re: Removing Leafs
« Reply #5 on: March 16, 2009, 02:23:25 pm »
Personally, I wouldn't do this on a 4WD truck.
Re: Removing Leafs
« Reply #6 on: March 16, 2009, 10:09:32 pm »
x2
Re: Removing Leafs
« Reply #7 on: March 20, 2009, 10:36:18 am »
and  whats your reasoning more or less just wondering i just don't want to block the front of my truck... and is there a way to measure my springs out of the truck and how much do they usually sag when there in???
Jack'em High
Offline Chevalade
Re: Removing Leafs
« Reply #8 on: March 20, 2009, 04:46:15 pm »
Never ever put blocks on the front axel. That is a major disaster waiting to happen.
Ryan
Re: Removing Leafs
« Reply #9 on: March 22, 2009, 04:08:46 am »
Fyi i said i didn't want to block it...... i know what a danger it is, i want my front axle under my motor not my gas tanks, that would suck more then a shop vac.....  LOL :D
Jack'em High
Re: Removing Leafs
« Reply #10 on: March 23, 2009, 03:51:04 pm »
Lift kits are designed for load and height, removing springs will effect the ride and eventually sag.
Re: Removing Leafs
« Reply #11 on: March 25, 2009, 01:09:36 pm »
i see you have a good point but how do easy rides work then?
Jack'em High
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Removing Leafs
« Reply #12 on: March 25, 2009, 01:12:03 pm »
Since he has a 3/4 ton, maybe some 1/2 ton springs will swap in since he won't be working it hard?
Re: Removing Leafs
« Reply #13 on: March 25, 2009, 07:02:34 pm »
Removing leaves is never a good idea. My 84 stepside has leaves removed. Ruined the ride.
Re: Removing Leafs
« Reply #14 on: March 25, 2009, 08:07:59 pm »
Same answer as above lift kits are designed for the application.  Ride, height and load.
