Author Topic: transfercase  (Read 37588 times)
Offline hotrod24
Re: transfercase
« Reply #30 on: February 05, 2009, 05:05:34 pm »
yea i can see if i can find a 700r4 and 208 set up but it looks like the 205 is winning lol
« Last Edit: February 06, 2009, 09:30:09 pm by hotrod24 »
1978 pontiac grand prix...
Offline hotrod24
Re: transfercase
« Reply #31 on: February 06, 2009, 09:33:50 pm »
ok i have a 383 that i will be putting in and i will be swaping for another transfercase and tranny but right now i have a th350 and a 203 tcase so if i was to get the th400 and 205 what would i need to get from the parts truck?
Offline joesgarage71
  • Wrench
Re: transfercase
« Reply #32 on: February 07, 2009, 09:58:54 pm »
 Crossmember, torque converter, both driveshafts, the Alum.400 conveter cover with the two strut arms, the trany lines, dip tube and the vacuum line(manifold to modulator) The gas pedal assy.with switch and the wire from the switch to the transmission. any and all the attaching hardware.
Offline hotrod24
Re: transfercase
« Reply #33 on: February 07, 2009, 11:46:55 pm »
wow i can do that if i can find everything lol
  • Wrench
Re: transfercase
« Reply #34 on: February 09, 2009, 07:01:25 am »
 If you can find everything?
Good parts truck will have everything you need.
Offline hotrod24
Re: transfercase
« Reply #35 on: February 09, 2009, 02:04:46 pm »
yea i have to check one junk yard and if he does not have a truck then i will have to check a few more but i am hoping that one of them has what i need
Offline 1976Scottsdale
Re: transfercase
« Reply #36 on: February 10, 2009, 10:26:33 pm »
I always liked my 203's as full time.  The kit saves some mileage, but not a great deal and it does cut down on wear on the front axle, but again, go through the frontend and replace the joints and put in some good greasable ones and service them when they need it.  Course, I like the front drive flanges... when its time to play I just drive in rather than get out and lock the front or hope the auto hubs work, my stuff is tied in forever.
Offline hotrod24
Re: transfercase
« Reply #37 on: February 11, 2009, 09:23:00 pm »
hey has any body on here seen a cross member and a skid plate on there 4x4 trucks like this i just have the cross member for the transfer case and transmission both but it shows in my haynes manual with a cross member for the transmission and a skid plate
                                           my truck
« Last Edit: February 12, 2009, 10:52:26 am by hotrod24 »
Offline hotrod24
Re: transfercase
« Reply #38 on: February 12, 2009, 02:36:44 pm »
i just dubble checked and i have holes for a skid plate on the passengers side but not the other side i was thinking that maybe it was just on 3/4 ton or 1 tons
Offline cracker0169
    • Myspace
Re: transfercase
« Reply #39 on: February 16, 2009, 04:32:18 pm »
I have an extra factory crossmember, and I have considered bolting that as shown and mounting some steel to it. With my truck being a long wheel base, I would hate to tear my 205 up if I got it high centered!
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
Offline hotrod24
Re: transfercase
« Reply #40 on: October 24, 2009, 12:24:52 am »
can you bolt up a 205 to a th350?
Offline Donut
Re: transfercase
« Reply #41 on: October 24, 2009, 06:03:56 am »
Yes, (that's what 's on mine)  You just need to find the transfer case with the correct input shaft.  Don't quote me on this, but I believe the th350 was 27 spline, and the th400 was 32.  If you are going to do more than putting a part time kit into the 203, personally I'd be looking for a parts truck.  You'd have the trans, transfer case, adapter, crossmember, and driveshafts if you needed a different length.
If cost is a factor, I wouldn't discount the 203, how many years did it run in your truck before the teardown?
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline hotrod24
Re: transfercase
« Reply #42 on: October 24, 2009, 11:39:07 am »
ok good i have a th350 just need to find a 205, would i need the 203 for this at all? and yea i have been looking for a parts truck but i did not ever drive this truck it sit most of the time
Offline Engineer
Re: transfercase
« Reply #43 on: October 25, 2009, 12:04:17 pm »
The NP205 is worth every penny.  :)
I have seen these things hold up to some pretty radical 4x4 truck pullers with out fail.
Also, I didn't see it mentioned yet, but the NP205's ID tag is on the front of the case underneath the 2 shift rails.
It is typically a square piece, especially on the older models, and not round like all of the other NP/NVG t-case models.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline thirsty
    • Suitor's Garage
Re: transfercase
« Reply #44 on: October 25, 2009, 01:42:37 pm »
I just realized a week ago that there is a difference in input shafts for the np208. I had a 81 208 that was behind a th350 and the shaft was smaller than the one behind my 4 speed. Make sure you get the right one for whatever trans you decide on. Whole parts rigs are the best.
I put a mile marker kit into a 203 about fifteen years ago. I can't remember the particulars but it was easy, worked perfect, and I used that truck for mud bogs. Never had a problem with that 203.
