Author Topic: Timing  (Read 4216 times)
Offline tgzzzz
Timing
« on: January 29, 2009, 09:38:29 am »
I have just installed a used pre-86 350 engine in my 11k# motorhome. All emmisions stuff has been removed. I'm wondering what the timing should be to set to. It starts fine at 8D BTDC. But a marine mechanic says he sets 350s at zero in boats due to the similar weight/resistance.
Any thoughts on this?
Re: Timing
« Reply #1 on: January 29, 2009, 10:11:08 am »
As long as it starts easy and idle quality is good, do the ole advance it til it pings and reatard it. Then check and record your timing settings. After that you can play around with your advance curve.
Offline tgzzzz
Re: Timing
« Reply #2 on: January 30, 2009, 05:27:36 am »
thanks, can't find anyone who agrees with setting at zero.
Re: Timing
« Reply #3 on: January 30, 2009, 06:41:43 am »
Zero is for computer controlled ignition timing
