Author Topic: My 1980 C-10  (Read 208006 times)
Offline Flamingbig10
Re: My 1980 C-10
« Reply #165 on: December 07, 2010, 11:31:29 pm »
got some work done, installed the cam, ls2 chain, oil pump,wind age tray, h3 pick up tube with new o ring, h3 oil pan, and valley, this weekend I plan on installing the valve springs and push rods, also picked up a v max 3 piece cover from gm, and also need to get a new crank pulley bolt
Offline eventhorizon66
Re: My 1980 C-10
« Reply #166 on: December 08, 2010, 01:21:08 pm »
 :-* (<- that's whistling, not kissing)
'85 C10 SWB 350 700R4 TKO600
Re: My 1980 C-10
« Reply #167 on: December 23, 2010, 07:37:28 am »
thanks
Re: My 1980 C-10
« Reply #168 on: January 09, 2011, 11:04:19 am »
After 3 tries I finally got a good 4l80e the first try was from lkq the pan was full of metal, so they sent me another one from up north some where and it was a 4l60e so I called them and they said we don't have any more 4l80e and will come and get and give you your money back, so I went to another yard and got one for $200 less and it  only has 30,000 miles.  Painted  the tb and belt tensor and installed a arp crank pulley bolt. Yesterday swapped over the suspension from the good frame to my truck so I can start cleaning up and painting the parts, also will be replacing the floor pans the first time I  used the cover over pans, so I picked up some pans from the forum store so  I pulled the gas tank from my truck and gutted the interior, wile was tearing down the suspension my dad was pulling out the patch panels and started cutting out the driver side pan
« Last Edit: January 09, 2011, 11:09:30 am by Flamingbig10 »
Re: My 1980 C-10
« Reply #169 on: January 09, 2011, 06:34:41 pm »
didn't get much done today because of this
I left the three inch drop springs in for a simple install
and for some reason the floor pans are really short where they start to angle up so it looks like have to cut some metal off the old patch panels
Re: My 1980 C-10
« Reply #170 on: January 11, 2011, 04:25:30 pm »
you should have ordered the extended floor not the standard floor.
Re: My 1980 C-10
« Reply #171 on: January 11, 2011, 10:27:28 pm »
oh I was going by picture in your store
mine stops at the red line
Re: My 1980 C-10
« Reply #172 on: January 14, 2011, 08:18:53 pm »
Really!  Was it labeled 0850-223?  Did it have the backing plate?
This one would have laid in the hole:
Re: My 1980 C-10
« Reply #173 on: January 15, 2011, 09:32:44 pm »
it has 850-223 wrote in black marker
and got the driver side floor pan cut out and will have to make a new channel for the weather stripping it was rotted out
« Last Edit: January 15, 2011, 09:41:32 pm by Flamingbig10 »
Re: My 1980 C-10
« Reply #174 on: January 16, 2011, 11:51:43 pm »
cleaned and painted the steering parts today I picked up new grade 8 hardware for the steering box,idler arm, and disc brake valve
Re: My 1980 C-10
« Reply #175 on: January 20, 2011, 11:10:54 pm »
Re: My 1980 C-10
« Reply #176 on: January 21, 2011, 07:38:00 pm »
I will check on that pan, but it wouldn't have covered as much as you need.
Re: My 1980 C-10
« Reply #177 on: January 22, 2011, 11:56:30 pm »
I got rear diff and flip kit swapped out but I'll need to install new leaf spring bushings, center pin, new rear shocks since my beltecs are shot I believe I use front shocks maybe some Monroe's, install new brake line and repaint every thing
Offline drag80
Re: My 1980 C-10
« Reply #178 on: January 24, 2011, 08:48:34 pm »
what are you doing for the engine wiring harness and ECM? just wondering, i'm about to do the same LS swap
jarett
Re: My 1980 C-10
« Reply #179 on: January 25, 2011, 06:13:06 pm »
I plan on getting a harness made and where ever I get it done I'll send the computer off maybe here
http://lt1conversion.com/product-details.php?id=44
