Author Topic: My 1980 C-10  (Read 207951 times)
Re: My 1980 C-10
« Reply #180 on: January 25, 2011, 06:52:16 pm »
I was quoted $300 to modify my harness from a guy on Ft. Worth. He has lots of knowledge in it, actually has a 5.3 in his 86 Sub. i can check with him for you if you want. He's close to you and that'll help on the convenience if questions arise.
Re: My 1980 C-10
« Reply #181 on: January 26, 2011, 05:49:35 pm »
I will check on that pan, but it wouldn't have covered as much as you need.
Called and found that the ran out of the one I generally sell and they filled the order with its equivalent.
Offline Flamingbig10
Re: My 1980 C-10
« Reply #182 on: January 29, 2011, 12:25:01 am »
yes
Re: My 1980 C-10
« Reply #183 on: January 29, 2011, 12:25:44 am »
thanks for the heads up
Re: My 1980 C-10
« Reply #184 on: January 29, 2011, 12:27:27 am »
got some work done today
pulled the c-notchs out of my old frame
there was still brake fluid in the caliper when I went to attach the hose to caliper the fluid dripped out and stripped most of the paint, they'll look ok till I get some willwood d-52s
brake line installed just need to install the brackets
starter installed and torqued down the torque converter bolts
Re: My 1980 C-10
« Reply #185 on: January 29, 2011, 07:36:08 am »
yes
I sent him a message, will let you know as soon as he gets back to me.
Re: My 1980 C-10
« Reply #186 on: January 30, 2011, 09:48:40 pm »
thanks chop top
Today worked on some rust repair and found more than I expected
the rust on the braces is surface rust
Re: My 1980 C-10
« Reply #187 on: February 12, 2011, 10:07:48 pm »
got the valve covers and coil packs on and swapped out the power steering pump for a non hydro boost unit
Re: My 1980 C-10
« Reply #188 on: February 16, 2011, 11:33:00 pm »
I got a few parts today, thermastat, coolant steam line crossover tube, " the original one was crushed by a chain"  ignition switch, dimmer switch, front bumper brackets, lower cowl patch panel, and qt of pr15, also got a little work done, got one leaf spring bushing pressed out and a new one pressed in, steam line installed, and the steering wheel, and levers pulled off the column and started sanding on it
Re: My 1980 C-10
« Reply #189 on: April 01, 2011, 09:38:40 pm »
Re: My 1980 C-10
« Reply #190 on: April 01, 2011, 09:41:26 pm »
Re: My 1980 C-10
« Reply #191 on: April 02, 2011, 03:48:00 am »
     That is a lot of work you have been doing, like the progress.
Offline roadrage41
Re: My 1980 C-10
« Reply #192 on: April 02, 2011, 07:24:24 am »
running regular or dual pass radiator?
« Last Edit: April 02, 2011, 07:27:32 am by roadrage41 »
Re: My 1980 C-10
« Reply #193 on: April 02, 2011, 03:36:48 pm »
thanks and yes its a regular radiator
Offline Tezjoe84
Re: My 1980 C-10
« Reply #194 on: April 11, 2011, 01:08:35 am »
Nice work! You going back to the winstar this year?
