Author Topic: 6 inch lift?  (Read 16831 times)
Offline 355shortbed
6 inch lift?
« on: February 03, 2009, 04:31:26 pm »
im considering purchasing a 6 inch lift for my 77 k10. What all extra stuff do i need like brake lines etc. and whats the best,-cost effective kit??? What problems might i run into, and expect? The cheapist i found was a rancho kits from 4x4groupbuy.com for $450 that seems cheap but it says comes with kit and shocks
Re: 6 inch lift?
« Reply #1 on: February 03, 2009, 04:53:06 pm »
This Rough Country kit?
http://www.4x4groupbuy.com/store/rough-country-7787-pickup-blazer-suburban-suspension-lift-p-8322.html
I have bought several stuff from them when I had my Jeep.
Re: 6 inch lift?
« Reply #2 on: February 03, 2009, 05:42:17 pm »
I highly recommend getting the rear springs instead of blocks, some good extended brake lines, and an over the spring steering link.
Offline 355shortbed
Re: 6 inch lift?
« Reply #3 on: February 03, 2009, 06:24:53 pm »
yea thats the kit im talking about. i would go with springs in the rear but unfourtunatly im on a tight budget  :(. what kind of brake lines would i need in the rear?
Offline 355shortbed
Re: 6 inch lift?
« Reply #4 on: February 03, 2009, 06:31:54 pm »
well on the rancho site its only 200 buks more for springs, whats the difference in springs and blocks?? just the ride quality?
Re: 6 inch lift?
« Reply #5 on: February 03, 2009, 06:35:50 pm »
Ride, stability, looks. Go with the springs if you can afford it.
Re: 6 inch lift?
« Reply #6 on: February 03, 2009, 06:39:19 pm »
Its a whole world of difference. It looks better, rides better, all around better. Save the $200 bucks and get them. Or, I will send you $200 and my blocks and bolts, and you can send me the springs. LOL With blocks, look at it this way. When you romp on it, the axle twists. Now, picture a pipe wrench on the axle. The higher you grab on the handle the more you can twist it, the lower, not so much. Do you want to twist the tar out of your axle, or want it to mainain where its supposed to be? It would be a very good investment for $200, becuase I am looking at close to $400 just to get the rear springs now. I someone know where to get them cheaper, please let me know.
Offline 355shortbed
Re: 6 inch lift?
« Reply #7 on: February 03, 2009, 06:42:19 pm »
it looks like itll be $840 with springs. and 580 with  blocks shipped. i reckon i can pony up the extra  :), should i get the drop down sway bar brackets?     You Have a good point choptop!
Re: 6 inch lift?
« Reply #8 on: February 04, 2009, 11:54:36 am »
I agree with the above.  Get the springs in the rear.
Re: 6 inch lift?
« Reply #9 on: February 04, 2009, 06:02:00 pm »
If this will be primarily for street use, Id get the sway bar brackets. If you find them, lemme know. I need to order a set myself, but have had a hard time locating them.
Offline 355shortbed
Re: 6 inch lift?
« Reply #10 on: February 04, 2009, 06:55:39 pm »
they offer them as a add on to the kit at roughcountry.com i think their like 35 buks but not sure if they sell them alone, can always call and find out
Offline keller
Re: 6 inch lift?
« Reply #11 on: February 06, 2009, 07:22:34 pm »
I would not go with the Rough Country kit myself. I have one in my 75 gmc 4x4 the front springs are saging with only 5000 miles on it. And most of the miles are street. just my opinion
