Author Topic: 700r4/208 to sm465/205  (Read 12627 times)
Offline BigHemi353
  • Diesel Enthusiast
« on: February 09, 2009, 10:29:17 am »
I bought a sm465 off of craigslist lastnight. My 208 is bad. It came with the flywheel, bell housing and crossmember. I'm thinking I need the pedal assembly, clutch fork, driveshafts and not exactly sure of what else. Im not worried about the column right now because I'll cut and fiberglass it to make it look right. Question is what do I need to do and what else do I need and what is the best way of doing this?  Also, if anyone has pictures of their stock or modified clutch setup(pedal set up, floor, ect) it would be greatly apprieciated. Thanks, Andy
Offline frogman68
Re: 700r4/208 to sm465/205
« Reply #1 on: February 09, 2009, 10:42:45 am »
I will be tackling this my self soon.
Yes you will need the pedal assembly and all the parts down to the bellhousing. have you picked up the Sm465  yet ? make sure you have lots of help it is heavy.
Offline joesgarage71
  • Wrench
« Reply #2 on: February 09, 2009, 10:49:15 am »
 When I did the swap I had a parts truck, It had everything I needed. Its going to be tough to find everything you need, but not impossible, its out there. If I can help email me
 Steve
Offline frogman68
« Reply #3 on: February 09, 2009, 10:56:21 am »
Was just thinking, you can probably get a hydraulic pedal assembly if you wanted to should be easier.
I am going with the linkage because nothing says truck like having to put your whole body weight into putting the pedal in :)
  • Wrench
« Reply #4 on: February 09, 2009, 11:14:47 am »
 Ya you can go that route you'll need the bellhousing, slave cylinder and related parts for that set up from a I think 87 on up truck.
Offline BigHemi353
  • Diesel Enthusiast
« Reply #5 on: February 09, 2009, 03:43:36 pm »
Well, the hydraulic clutch does sound kind of nice. This is going to be my weekend cruiser so I probably will want it as comfortable as possible. From what you guys say I will need the bellhousing, slave cylinder, pedal assembly from an 87 and up? and what else will i need? also, didnt they have hydraulic clutches before 87?
and frogman, you werent kidding when you said it was heavy. we used a engine hoist to put it in my friends truck and i used our forklift to take it out. lol
Thanks guys, Andy
« Reply #6 on: February 09, 2009, 03:52:35 pm »
FYI: Hydraulic setup started in 1985, you can get a hydraulic setup from McLeod or Keisler also.
Offline frogman68
« Reply #7 on: February 09, 2009, 06:46:56 pm »
Thanks guys, Andy
I learned the hard way :) after the cab was off I unbolted it and at first thought it was stuck till it came out of the bellhousing glad the wife doesnt want anymore kids :)
Offline BigHemi353
  • Diesel Enthusiast
« Reply #8 on: February 10, 2009, 03:47:34 pm »
well, ive found a hydraulic bell housing. it comes with the dust cover, the rubber boot, shift fork and slave cylinder. hopefully i can get it. what else will i need besides the pedals, lines and master cylinder? Thanks Andy
« Reply #9 on: February 10, 2009, 05:14:34 pm »
I think you got it covered with what you have listed.
Offline BigHemi353
  • Diesel Enthusiast
« Reply #10 on: February 10, 2009, 06:31:13 pm »
Great. Just bought the master cylinder at Advanced Auto. Need reservoir though. Hopefully have everything far as bellhousing, fork, slave cylinder, ect. One more question. Are all of the 73-87 clutch/brake pedal assemblies all the same or are the 85's and up different? thanks alot guys, Andy
Offline heyharris1
« Reply #11 on: February 10, 2009, 09:18:14 pm »
to bad you were not closer, i got a complete setup that i would trade you if you were closer, i was thinking about switching over to a auto
« Reply #12 on: February 11, 2009, 11:32:14 am »
The hydraulic setup is different but you can make it work..
Offline BigHemi353
  • Diesel Enthusiast
« Reply #13 on: February 11, 2009, 04:28:12 pm »
alright, then that is what i'll do then. I presume that I will have to make new holes in the firewall for the clutch master cylinder? i didnt see a place or a punch out for it. Thanks Andy
