Author Topic: Help w/ 79 Blazer Transfer Case  (Read 3860 times)
Offline Countryboy506
« on: February 15, 2009, 01:28:27 pm »
Hey everyone.
  I have a 1979 Chevy K5 Blazer 4x4. with Np203. Now I know these are suppose to be Full Time ( Unless converted ). My question is how can I tell if mine has been converted? It has Locking Hubs in the front. The T-case shifter reads as follows
Low Loc
Low
N
Hi
Hi Loc
Ive been driving ( Normal Driving conditions ) with the hubs in the FREE position.
So how can I tell if it has the Part Time Conversion kit?
And if it does, how should I drive it, like on highway with normal conditions? ( like Hubs in Free? And in Hi or Hi loc?
And what about if it doesnt
Thanks so much!
Matt
Offline Prong
Re: Help w/ 79 Blazer Transfer Case
« Reply #1 on: February 15, 2009, 02:24:02 pm »
If it moves in the 4 hi (not 4 lock) position with the hubs unlocked, it's been converted. Once converted, the Hi position is now 2wd. The Lock positions are now 4wd. You also now can put it in Lo for 2wd low range as well. Don't run it on *dry* pavement in the Lock positions, because you'll bind things up and possibly start breaking things. For normal driving leave it in Hi with the hubs free. However, once in a while lock the hubs and drive it a few miles to splash the oil around in the diff and lube up the axles.
« Last Edit: February 15, 2009, 02:29:37 pm by Prong »
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
