Author Topic: fuel efficieny questions/issues  (Read 13157 times)
Offline muddnutz
« on: February 17, 2009, 08:36:01 pm »
  I have a stock 305 with dual flows, stock exaust manifold,edelbrock intake and carb(1407?) lucky to be getting 10 mpgs wich really sucks on a 16 gallon tank and family lives 180 miles away. what can I do to improve  it.   my truck is a 86 k-10 no lift on 31's stock gears
Re: fuel efficieny questions/issues
« Reply #1 on: February 17, 2009, 10:35:39 pm »
Check your rear gears. It should be ok with 3:73's. but it could have higher gears which wouldlug the engine. Other than that, it may be a tune up issue
Offline 82Shortbed
« Reply #2 on: February 17, 2009, 10:44:03 pm »
1407 seems like too much carb for a 305, its a 750 manual choke.
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline muddnutz
« Reply #3 on: February 18, 2009, 05:38:11 am »
may have no. wrong it is a 600 electric choke ..new plugs ,wires, cap and rotor-timing marks are hard to read on balancer  ??? also 700r4 tranny  whatever the factory gears are in a stock plain jane k-10.they have never been changed i got thee truck from my dad he bought it new in Oct 85...also no emissions on it anymore
« Last Edit: February 18, 2009, 05:50:24 am by muddnutz »
« Reply #4 on: February 18, 2009, 10:24:46 am »
check your carb # to be certain of what it is.
Offline eventhorizon66
« Reply #5 on: February 18, 2009, 11:10:50 am »
Well you need to know your ignition timing.  Even if it's where it should be, you can usually advance it a few degrees without consequence to improve efficiency.  The find the TDC mark (groove) on your balancer, clean it, and paint it (steal some of your GF's/Wife's white nail polish).  That will make it clear as day.
'85 C10 SWB 350 700R4 TKO600
Offline muddnutz
« Reply #6 on: February 19, 2009, 02:15:14 pm »
  CARB IS A 1406---600CFM ELECTRIC CHOKE  ILL HAVE TO BORROW NEIGHBORS TIMING LITE TONITE.  DOES IT NEED TO BE ON THE LINE OR OFF TO THE LEFT OR RIGHT? NO BEFORE OR AFTER MRKS JUST A LINE ON THE DAMPER--NO TAB ON TIMING COVER
« Last Edit: February 19, 2009, 02:17:19 pm by muddnutz »
« Reply #7 on: February 19, 2009, 05:20:28 pm »
how can you time it using a timing light without a pointer?
Offline enaberif
« Reply #8 on: February 19, 2009, 06:53:19 pm »
With skills!
Or perhaps he overlooked it as I did!
« Reply #9 on: February 19, 2009, 07:01:27 pm »
I bet he did.
Look straight down behind the water pump.  It should be at the 12 'o clock position on the dampner.
Offline muddnutz
« Reply #10 on: February 19, 2009, 07:47:20 pm »
 i see the pointer  what I'm asking is should it be dead on with the mark or a few deg btdc or aft? you cant tell on the pointer just a few jagged edges which line is which
Offline rockable
  • Truckin', like the do-dah man.
« Reply #11 on: February 19, 2009, 07:53:02 pm »
'86 should be 4 degrees BTDC with the vacuum disonnected from the distributor and plugged.  That truck should get 15 city/20 hwy thereabouts, if it's tuned and carbed correctly.  You've got a lot of room for improvement, assuming the long block is up to snuff.
As I recall, each "tooth" on the marker is 2 degrees.  TDC is to the right.  You really need to clean it off, so that you can read it.
« Last Edit: February 19, 2009, 07:54:54 pm by rockable »
'86 SWB Silverado
Offline muddnutz
« Reply #12 on: February 19, 2009, 09:50:39 pm »
  it is a rebuilt 305 haven't checked comp or sure on mileage since dist is also aftermarket pos box fried a while ago.. don't mean to sound like such a dumbarse but timing pointer isn't marked which is tdc, it has several points and a tube beside it? does this make any sense my camera died or i would take a pic
Offline Jims86tpisub
« Reply #13 on: February 19, 2009, 11:19:33 pm »
If its an 86, I wonder if it came with the computer controlled q-jet....If he changed the carb., that may be his problem....no tps to tell the computer what throttle position the carb is at.
Jim
1986 K10 Suburban
Tuned Port Injection
193 Heads
Comp 260H cam
700r4 Raptor
Single exhaust with 2 Magnaflow Mufflers inline
Offline muddnutz
« Reply #14 on: February 20, 2009, 05:44:32 am »
 no more comp. or comp controlled dist.
