Author Topic: dual tanks  (Read 8265 times)
Offline bbs80
dual tanks
« on: February 18, 2009, 03:54:04 pm »
I want to put dual tanks on mt 80 sw and look like it came from the factory with duals i have both tanks but nothing else can anybody tell me what else is need any where to get it.
Offline hotrod24
Re: dual tanks
« Reply #1 on: February 18, 2009, 04:52:20 pm »
first off do you have a dual bed? you will need to cut a hole in your dash and you can get the switch and harness and pump and wiring from a junk yard
« Last Edit: February 18, 2009, 04:54:56 pm by hotrod24 »
1978 pontiac grand prix...
Re: dual tanks
« Reply #2 on: February 18, 2009, 09:03:22 pm »
The tank switching valve, switch, appropriate wiring, and hoses
Offline bbs80
Re: dual tanks
« Reply #3 on: February 20, 2009, 11:05:28 am »
the bed is set up for dual tanks, does anybody sell everything new to convert i really don't want to buy used because my luck i will end up replacing everything anyway.
Re: dual tanks
« Reply #4 on: February 20, 2009, 12:32:23 pm »
 You can get a switching valve, switch and hoses from autozone. The fuel tank filler pipes aren't available anywhere that I know of.
Offline bbs80
Re: dual tanks
« Reply #5 on: February 20, 2009, 02:10:28 pm »
i have the filler neck and that stuff nothing else i want turn turn my single tank to duals I'm putting in my big block and I'm going to need more fuel so autozone sells everything else
Re: dual tanks
« Reply #6 on: February 20, 2009, 06:06:49 pm »
what?
Offline bbs80
Re: dual tanks
« Reply #7 on: February 23, 2009, 09:38:19 am »
i have the filler pipe and hose for the tank, i need everything else to swap from side to side.
Offline levisjohnson
Re: dual tanks
« Reply #8 on: February 23, 2009, 11:10:16 am »
Has anyone ever put dual gauges for the dual tanks and did away with the switch in the dash?
Levis
88 6.2L Diesel 3+3 3/4 ton
Re: dual tanks
« Reply #9 on: February 23, 2009, 04:47:46 pm »
Why? the gauge switches with the valve so you know what the level of both is?
Offline bbs80
Re: dual tanks
« Reply #10 on: February 23, 2009, 05:40:20 pm »
i don't really know what i need i just want to add a 2 tank and switch it and the fuel Gage works
Offline gold84gmc
Re: dual tanks
« Reply #11 on: February 23, 2009, 07:12:14 pm »
you need all that minus the hoses because you already have them....im not sure but you might be able to get that stuff out of
92 buick century custom 3.3L
Re: dual tanks
« Reply #12 on: February 23, 2009, 08:05:44 pm »
I was just thinking...what if?
Levis
