Engine/Drivetrain
engine shutting off
Topic: engine shutting off (Read 3973 times)
plowking_90
engine shutting off
February 19, 2009, 12:25:42 pm »
i have a 90chevy 3/4 ton with 350 a throttle body engine every tim i hit a bump in the road or even when im driving on an open road the engine light flashes and the motor cuts out for a split second and will do it rapididly for a min or so at a time and suggestions will help before the truck is on fir in my driveway!!!!!
Re: engine shutting off
February 19, 2009, 01:22:00 pm »
What are the codes that it is throwing?
choptop
Extended cab fanatic
February 19, 2009, 03:34:20 pm »
Also check your grounds from the battery to the chassis and block. A loose or corroded one will cause alot of headaches
February 19, 2009, 04:52:45 pm »
With the engine running wiggle test all of your wires around the battery, distributor, firewall, bulkhead connector, ECM and fuel pump. See if you can duplicate it.
Engine/Drivetrain
engine shutting off
