Author Topic: changing speedo o ring  (Read 10853 times)
Offline 84chevysilverado
« on: February 19, 2009, 07:04:16 pm »
so my 700r4  is leaking around where the speedo shaft goes into transmision. I took the speedo cable off and took off the bolt that holds on the little cover covering the speedo gears. but i cant take off the cover, how big is this cover and where does it meet the tranny so i can pry it off?
Offline HAULIN IT
Re: changing speedo o ring
« Reply #1 on: February 19, 2009, 08:53:22 pm »
It's not really a cover like you may be thinking. It is more of a round slug with a groove around it for an O-ring IN a bore, so from the outside there isn't anything to "pry it off"... it's a "slide it out" deal. Maybe try squirting around it with penetrating fluid & scraping the edge of the bore a bit. Good Luck, Lorne
Offline Russ130
« Reply #2 on: February 19, 2009, 11:27:53 pm »
Yes be careful with it. That holds the driven gear in mesh with the drive gear for the speedo. I usually try and spin it a bit first then I rock it a little as I'm pulling it out. I never use pliers or anything other than my hands to remove it.
Offline 69byrd
  • Haulin!
« Reply #3 on: February 20, 2009, 07:32:32 am »
I replaced mine and I rocked it alittle as I pulled and it came out.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: February 20, 2009, 10:53:36 am »
if I remember right, here's how it all goes together:
and here's what the part you take out looks like, the threaded part is where the speedo cable goes:
Offline HAULIN IT
« Reply #5 on: February 20, 2009, 03:44:01 pm »
Nice pic's Kenny!
« Reply #6 on: February 20, 2009, 04:10:21 pm »
There's a bulletin on the 700R4 for leaks at the speedo. I'll post it here in a sec.
« Reply #7 on: February 20, 2009, 04:16:19 pm »
Number: 87-138
Section: 7A
Date: May, 1987
Subject: FLUID LEAKS FROM THE PLASTIC SPEEDOMETER DRIVEN GEAR/ADAPTOR AREA
 ALL LIGHT DUTY TRUCKS WITH MANUAL OR AUTOMATIC TRANSMISSIONS
Figure No. 1EXTENSION AND ASSOCIATED PARTS
BULLETIN COVERS:
Transmission fluid leak at the plastic speedometer driven gear (44, Figure No. 1) can be caused by a hole in the driven gear shaft. In some cases, this condition could be misdiagnosed as a speedo driven gear fitting leak (43, Figure No. 1).
Figure No. 2
 SERVICE ACTION:
When servicing a vehicle for a fluid leak around the speedometer driven gear fitting or cable, check the speedometer driven gear shaft for a hole through the center of the shaft as follows: (Figure No. 2)
1. Install a hand vacuum pump over the end of the gear (opposite gear teeth).
2. Pump up 10 in.-hg. of vacuum.
3. The gage should stay at 10 in.-hg for at least 30 seconds. -If the gear holds vacuum, inspect the seals in the adaptor. -If the gear does not hold vacuum, replace the gear.*
*Note: Check the new gear from parts stock as outlined before installing in transmission.
SERVICE PARTS:
Refer to the GM Service Parts Operations (GMSPO) Catalog for the current speedometer gear based on transmission model and year.
« Reply #8 on: February 20, 2009, 08:00:01 pm »
thanks guys ya really helped me out
thanks marc :D
