Author Topic: trans problem  (Read 4907 times)
Offline necromonger
trans problem
« on: February 20, 2009, 08:42:11 am »
Hi,my 1983 gmc 3/4 ton 4 speed trans pop's out of 3rd gear need help.
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Re: trans problem
« Reply #1 on: February 20, 2009, 11:09:13 am »
All the time or on Decel?  If the later it needs new syncros.
Offline necromonger
Re: trans problem
« Reply #2 on: February 20, 2009, 12:12:09 pm »
all the time
Offline necromonger
Re: trans problem
« Reply #3 on: February 21, 2009, 08:54:05 am »
where can i get a rebuild kit for this trans?
Re: trans problem
« Reply #4 on: February 21, 2009, 09:10:50 am »
Which trans do you have? If it's a manual trans you'd need to get parts as required.
Offline necromonger
Re: trans problem
« Reply #5 on: February 21, 2009, 04:33:54 pm »
4 Speed cast iron
« Last Edit: February 21, 2009, 04:36:47 pm by necromonger »
Re: trans problem
« Reply #6 on: February 22, 2009, 09:06:09 am »
Offline necromonger
Re: trans problem
« Reply #7 on: March 02, 2009, 06:49:28 pm »
if it is a 465 3rd and 4 have snap rings used as spacers the snap rings get weak and bam  they make a bushing to replace the snap rings. but you get new snap rings in your rebuild kit i also would call novak and see if they have that bushing.
