87 Ignition Module Wiring
Topic: 87 Ignition Module Wiring (Read 33559 times)
DnStClr
February 24, 2009, 11:41:36 am »
I kinda goofed- I was putting in a new ignition module in my 87 tbi distributor- a 15 minute job, right? Well company showed up; I lost track of which wire from the pickup coil goes to which module pin- and now I can't get a good wiring shot of it from my manuals.There's only 2 small wires- a green one and a yellow one. The two pins on the module are P and N. And of course,I can't resize a drawing from the manual, it keeps coming out so small that it's useless,so I hope that's enough info-
Don
87 Chevy Silverado
Re: 87 Ignition Module Wiring
February 24, 2009, 09:22:08 pm »
Realistically it doesn't matter. Did the plastic clip disintegrate? Most replacement pick up coils aren't even color coded
⌠ŻŻŻŻŻ' [☼===☼]
DnStClr
February 25, 2009, 12:28:41 am »
A Plastic clip wasn't there. Thanks Vile.
Don
87 Chevy Silverado
DnStClr
March 02, 2009, 10:03:38 am »
Well I need to ressurrect this starting problem. The truck starts and runs for @20 seconds and shuts down.I have replaced the fuel pump relay and checked it's wiring. I stuck another throttle body on, I replaced the tps, I tried another computer, and replaced the ignition module. It acts the same using either fuel tank.Can a faulty
oil pressure switch
be the culprit, since it is tied in to the fuel delivery system ?
Don
87 Chevy Silverado
March 02, 2009, 11:29:41 am »
No. Once the engine is started the oil pressure switch is out of the picture until next start up. Are you losing spark? Check the pick up coil.
⌠ŻŻŻŻŻ' [☼===☼]
DnStClr
March 02, 2009, 11:39:05 am »
OK. I was hoping it wasn't fuel related.
Don
87 Chevy Silverado
DnStClr
March 06, 2009, 12:49:22 pm »
Removed the distributor cap again and couldn't remove the pickup coil. after some 'skunk pee' (Blazin words) and a puller, it came off in pieces. Distributor shaft is pretty rusty. Also, the replacement coil sure looks different than the original when they're next to each other. .Once I took off the rotor and saw the pick up coil, I didn't bother with a spark check. It looks like I'll probably need to do that. lol
A plate is still left at the bottom and it has a roll pin in it. I assume this plate is the bottom part of the pickup coil. Does the plate come off with the bearing race? ( I hope so since I broke it)
Last Edit: March 06, 2009, 01:01:33 pm by DnStClr
Don
87 Chevy Silverado
choptop
Extended cab fanatic
March 06, 2009, 01:10:43 pm »
Ok, somebody straighten me out here. I thought the pickup coil had to be replace from the bottom by removing the distributor, the cam gear, and then go from there. Either way, I think it would have been easier to pull the distributor first.
DnStClr
March 06, 2009, 01:56:24 pm »
On the tbi distributor the pickup coil sits on the shaft right below the rotor. Modular type. Two wires come out of it to feed a signal to the ignition coil sitting right beside it under the distrib cap. That signal is sent to the ecm along with a signal from the knock sensor to determine how the ecm wants to set the timing. (That's my take on it anyhow)
But it's serviceable from the top. Sort of.
Don
87 Chevy Silverado
March 06, 2009, 03:42:08 pm »
No you need to remove the distributor and slide out the pole piece. Knock the gear roll pin out. Note the dot faces toward the slot for the rotor.
⌠ŻŻŻŻŻ' [☼===☼]
March 06, 2009, 03:42:55 pm »
I just looked at your pix. Don you broke the pole piece. Time for a new distributor.
⌠ŻŻŻŻŻ' [☼===☼]
choptop
March 06, 2009, 04:30:51 pm »
Yay, Im not crazy. Sorry Don.
DnStClr
March 06, 2009, 09:16:53 pm »
Nuts. Well not all is lost. Maybe I can upgrade to a better distributor.
Don
87 Chevy Silverado
choptop
March 06, 2009, 09:20:10 pm »
Quote from: DnStClr on March 06, 2009, 09:16:53 pm
Now you're thinking.
DnStClr
March 07, 2009, 07:57:28 am »
Being self-taught can be rough on a guy at any age
Don
87 Chevy Silverado
