Interior & Equipment
Power Windows & Door Locks
Strange problem with power window ('87 model)
Topic: Strange problem with power window ('87 model) (Read 17002 times)
Skunksmash
March 05, 2009, 06:15:31 pm »
My passenger side power window switch was broke, (didn't function) old, and ugly. A lot of the chrome had peeled off. So i was glad to find that my local auto parts store had a nice new replacement for me under their "Help!" section. I am sure you have seen this section before. Well, the new one works, sort of. You can roll down the new one all the way, if you want to. You can also roll it up all the way if you want to... but only if you did not roll the window down all the way. You have to leave 3 inches of window showing for it to work
going back up
. But, it works fully from the driver's side. Any ideas?
I am starting to think that these aftermarket switches are of very poor quality. I also bought a new driver's side door lock switch, and the thing is reversed. The word "Lock" is in the right spot and is right side up, but you have to flick the switch
up
to get the doors to lock, and
down
to get the doors to unlock... kind of annoying to have two brand new parts be so glitchy. I may just be used to Ford, but i think it's safe to assume GM didn't want it to seem backwards. (first one of these trucks i have had with power locks)
Last Edit: March 05, 2009, 08:14:03 pm by Captkaos
Re: Strange problem with power window ('87 model)
March 05, 2009, 07:00:42 pm »
check the wires on both doors between the jam and the door. Also check the wires inside the door.
Skunksmash
April 02, 2009, 09:42:47 am »
Got into the wiring, and man is this thing messed up. Come to find out, the driver's side does actually work, it was just unplugged. So i plug it back up, and now when you press down on the driver's side, it locks the driver's side. But at the same time it
unlocks
the passenger side. And of course when you press up on the driver's side, the passenger side gets locked. Now here is the weird part. In my humble opinion, this thing hasn't been messed with by someone who had no clue what they were doing, in the past. I mean, to look at all the wiring and such, you would think it is still all in stock configuration and such. There are no telltale signs such as spliced wires, electrical tape haphazardly put on, missing wire loom, stripped wires, ect. If someone has been messing with it, i can't tell. And i have seen some pretty darn shoddy electrical work in my day, as im sure you all have. So is is possible that this is some sort of weird, uncommon factory defect thing? Cause from where i am sitting now, it looks as though
I
am the one who is going to have to go switching things all around, and cutting and splicing wires if i wanted to take the easy way to get this thing to function properly.
My buddy suggested that it could be an internal malfunction of the actuators themselves, but i find that highly unlikely. First of all i have never heard of an actuator that malfunctioned in such a way. Second, it would be a very big coincidence for both sided to get the same internal malfunction. More likley only one side would do it if it were true. Oh and for the guys who have never tore into one of these yet, it can not be a switch problem of any kind, as it is only possible to connect the switch to the wiring connector
one way
. That and both of the switches are brand new. Anyone have any ideas on what the problem could be? I have been through just about all of the wiring in the lock system trying to find the cause, to no avail. I am about to just totally rewire the whole setup so that i know that it is correct.
Last Edit: April 02, 2009, 09:49:52 am by Skunksmash
ccz145a
April 02, 2009, 09:46:30 am »
sounds like you need the same type of lock switch on each side.
Skunksmash
April 02, 2009, 09:51:18 am »
That is another thing i thought about, and i needed to ask one of the vets here if there is any difference at all between the two. It did not look like there was when i held them up close to each other, but looks can be deceiving....
ccz145a
April 02, 2009, 10:01:41 am »
they may both work "wrong" when your done (up on switch to lock the doors) but at least they will both work the same way. once you have them working the same way, then you can cut and splice the wires to both switches to make them "right".
Just a thought, can you flip the connector and rotate and reconnect at just the new switch?
Skunksmash
April 03, 2009, 08:14:32 am »
Yeah i probly can. Either that or splice like you said. I was just looking for a way to do it that would not alter the factory settings all that much. I know that during a restoration that there are times when the factory setup just aint going to happen, (for one reason or antoher) but i like to try. Oh well.
musicitymafia
April 03, 2009, 04:18:03 pm »
The door locks are the same part # on both sides. The switch itself will come out of the chrome bezel if you pop off the clips. Maybe it got put in backwards in china town, everything IS backwards over there. Either way pop the clips and turn over, maybe that will work.
1985 Chevy Silverado SWB 305
MPS LEAD THE WAY
GoatBeard
April 03, 2009, 07:23:40 pm »
Mine was stuck all the way down for upwards of a year. One day my wife needed to drive it to work for whatever reason. She gets in, pushes the button up and it goes up!!! I started jumping up and down and with a horrified look on her face she said, "Did I do something wrong?"
To this day I won't roll that window down all the way -- so leaving 3" is probably not such a bad thing in the big picture.
Skunksmash
April 08, 2009, 12:46:57 pm »
It's actually a very simple switch. You can just sort of peel the backplate out, and reposition that little metal bar in there to fix it when they get stuck. Although you may have to JB-Quick the plastic backplate back on. They like to keep popping back out once you have taken them apart.
