Author Topic: Identification of a part  (Read 6013 times)
Offline harrishawk
« on: March 07, 2009, 11:08:18 am »
This is attached to my distributor (?) near the back of the engine on the left side of the air cleaner. It has a hose that attaches to it that has rotted into. The truck is an 84 Silverado 8 cyl and runs okay. Just need to know if I need to replace the hose. Thanks
Offline HAULIN IT
Re: Identification of a part
« Reply #1 on: March 07, 2009, 11:33:32 am »
Harrris, That is the vacuum advance canister, it varies the ignition timing based on engine "load", yes you would want to replace the hose, the other end will go to the carburetor. Lorne
Offline harrishawk
« Reply #2 on: March 07, 2009, 11:39:23 am »
Thanks!  I appreciate your help.
« Reply #3 on: March 07, 2009, 01:30:41 pm »
Make sure the end on the carb only has vacuum when the accelerator is cracked. No vacuum when at idle.
Offline harrishawk
« Reply #4 on: March 07, 2009, 04:39:52 pm »
Got it fixed!  Y'all are saving me alot of money.  Thanks, so much.
Okay, here is another one - if you don't mind.
This piece looks like it has been disconnected for awhile.  Very rusted.
Offline DnStClr
« Reply #5 on: March 07, 2009, 07:30:27 pm »
I'm thinking that tubing was originally hooked into a heat riser valve that was installed in the exhaust manifold, where the flex hose, or stove pipe, is. The heated air was used somewhere else- wherever that tubing goes to. Does it go down to the oil pan?
Don
87 Chevy Silverado
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: March 07, 2009, 08:08:51 pm »
If you can get us a pic of what it goes to, the other end.  could either be a heat riser like DnStClr said or may goto the transmission modulator.?
Offline harrishawk
« Reply #7 on: March 07, 2009, 08:10:18 pm »
There was a about a 6 inch piece of tubing that was laying on the ground underneath.  It fits the end of the metal piece - but I've looked for a connection point and can't find one.
  • Z62 ON-ROAD
« Reply #8 on: March 07, 2009, 08:19:39 pm »
Look where the exhaust manifold meets the exhaust pipe.  is there anything in between the two that the tube might goto?  if not I don't know what it's for.
