73-87 Chevy & GMC Trucks
Identification of a part
Topic: Identification of a part (Read 6012 times)
harrishawk
March 07, 2009, 11:08:18 am »
This is attached to my distributor (?) near the back of the engine on the left side of the air cleaner. It has a hose that attaches to it that has rotted into. The truck is an 84 Silverado 8 cyl and runs okay. Just need to know if I need to replace the hose. Thanks
HAULIN IT
Re: Identification of a part
March 07, 2009, 11:33:32 am »
Harrris, That is the vacuum advance canister, it varies the ignition timing based on engine "load", yes you would want to replace the hose, the other end will go to the carburetor. Lorne
harrishawk
March 07, 2009, 11:39:23 am »
Thanks! I appreciate your help.
Blazin
Blazin new trails!
March 07, 2009, 01:30:41 pm »
Make sure the end on the carb only has vacuum when the accelerator is cracked. No vacuum when at idle.
harrishawk
March 07, 2009, 04:39:52 pm »
Got it fixed! Y'all are saving me alot of money. Thanks, so much.
Okay, here is another one - if you don't mind.
This piece looks like it has been disconnected for awhile. Very rusted.
DnStClr
March 07, 2009, 07:30:27 pm »
I'm thinking that tubing was originally hooked into a heat riser valve that was installed in the exhaust manifold, where the flex hose, or stove pipe, is. The heated air was used somewhere else- wherever that tubing goes to. Does it go down to the oil pan?
Don
87 Chevy Silverado
78 Chevyrado
Z62 ON-ROAD
Site Supporters
March 07, 2009, 08:08:51 pm »
If you can get us a pic of what it goes to, the other end. could either be a heat riser like DnStClr said or may goto the transmission modulator.?
harrishawk
March 07, 2009, 08:10:18 pm »
There was a about a 6 inch piece of tubing that was laying on the ground underneath. It fits the end of the metal piece - but I've looked for a connection point and can't find one.
78 Chevyrado
Z62 ON-ROAD
Site Supporters
March 07, 2009, 08:19:39 pm »
Look where the exhaust manifold meets the exhaust pipe. is there anything in between the two that the tube might goto? if not I don't know what it's for.
