Author Topic: Body trim  (Read 7397 times)
Offline 75 C20
Body trim
« on: March 26, 2009, 11:13:58 am »
Has anybody put the two tone trime on 73-80 and not used all the clips- just use liek 3m double sided tape? I was wondering if it would work well or if it would be a noticable gap between the trim and the body causing it not to look good.
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline ccz145a
Re: Body trim
« Reply #1 on: March 26, 2009, 11:59:39 am »
Wondering the same thing myself... sure would be a lot simpler to install!
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Body trim
« Reply #2 on: March 26, 2009, 01:56:14 pm »
It would work, as long as you use good tape, and get it on there good.  I used the stuff that came with the new trim and here and there some of it's already coming off.  I haven't bought any new tape yet to fix this, but when I do I'll have to try different thicknesses to make the trim fit up right, and not have a gap between the body and trim.  the only minus would be that if a piece should come loose on the freeway or something, it will blow right off and be gone.
Read the third post from the bottom, it has my thoughts on aftermarket trim if that's what you're using:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9881.0
Re: Body trim
« Reply #3 on: March 26, 2009, 11:23:34 pm »
Your talking about the aluminum trim with the black stripe correct? It will not stay on more than a few days with tape.
Offline Prong
Re: Body trim
« Reply #4 on: March 27, 2009, 02:53:32 am »
I used Panel bond on mine. That stuff will never come back off without using a moulding cutter.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline yellowk20
  • Truck Poor
Re: Body trim
« Reply #5 on: March 27, 2009, 02:13:41 pm »
Could you be more specific ?? who makes it? where can you get it ? have you used it on the metal trim?
"If you're Gonna be stupid you better be tough"
Offline Prong
Re: Body trim
« Reply #6 on: March 28, 2009, 10:09:58 pm »
Panel bond here: http://www.levineautoparts.com/3maupaboad20.html
The guns you use to apply are listed below on that page. I didn't get the stuff from these guys, they're just one of the first links that popped up. You generally use the stuff for attaching repair panels instead of welding. This stuff is tough--applied right it will not come off. I used it when I put my trim back on my 79 longbed, because that 2 sided tape just won't keep that trim attached to my satisfaction.
« Last Edit: March 28, 2009, 10:11:54 pm by Prong »
Offline 75 C20
Re: Body trim
« Reply #7 on: March 30, 2009, 06:45:53 pm »
did u put it on the paint? Did you rough up the paint to make it stick or???
Does anybody else have and experience putting that trim on- i really don't want to have drill all the holes and go through all that hassle unless it is the best and most efficient way.
