Author Topic: Tbi idle is too low.  (Read 11167 times)
Offline DnStClr
« on: March 26, 2009, 11:56:10 am »
I installed a new distributor, coil, plugs and wires, and can't seem to get the timing and idle right. (87 tbi, 350, 700R4 auto).
I unplugged the EST wire and removed the vacuum hose from the manifold and plugged the hose. Made sure the engine was at TDC with the rotor pointing at 6:30. The engine starts and runs good. When I move the distributor to align my timing marks, the timing light reads 940RPM. I tighten down the distributor at 0 degrees timing like the sticker on the radiator cover says.
After I install the air cleaner and plug the vacuum line and EST wire back in,start the engine back up, and it shows 560 RPM and the timing mark has moved to somewhere around 15-16 degrees advanced. The low idle causes the engine to stall, so I'm wondering about my procedures. Do they look right? On a tbi, should I not unplug the vacuum line from the manifold during timing setup?
Don
87 Chevy Silverado
Offline Russ130
Re: Tbi idle is too low.
« Reply #1 on: March 26, 2009, 12:58:47 pm »
Does the sticker on the radiator thingy say to unplug the vacumn line? If not then you should leave it plugged in.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #2 on: March 26, 2009, 03:11:45 pm »
Yeah the est wire and the vaccum line should be disconnected and plugged.
I can't remember the procedure, but there's way to reset or calibrate your IAC Idle Air Control Valve.  You have to do this when you get a new IAC, but I had to do it a couple of times to my old '87.  The IAC is similar in operation as a mixture screw, it's just a motor that screws in and out to allow more or less air past the valve.  It's real easy to do I just can't remember how.
Another thing could be the timing mark on the balancer is off.  If it's a high mileage engine the outer ring could have slipped on the inner hub.
« Last Edit: March 26, 2009, 03:14:28 pm by 78 Chevyrado »
« Reply #3 on: March 26, 2009, 03:22:08 pm »
To reset the IAC: Key off for 10 sec start the engine for 5 sec, key off for 10 sec again. Then unplug the IAC and start the engine.
« Reply #4 on: March 26, 2009, 05:03:38 pm »
Which vacuum line are you unplugging? Just put the EST in bypass and set the timing to 0°. After setting reconnect the bypass wire then disconnect the battery for 30 seconds and restart the engine.
Offline Russ130
« Reply #5 on: March 26, 2009, 05:41:16 pm »
You know for the life of me I don't ever remember unconnecting a vacumn line to set the timing on a computer controlled engine. Disconnecting the battery as Vile says will clear any codes that may come up from bypassing the EST.
Offline DnStClr
« Reply #6 on: March 27, 2009, 01:04:17 am »
 1. Ok.I'll reset the idle air control.
 2. Yes, I have been disconnecting the battery to reset the est fault.
 3. Well, actually Vile, (now that I look at it better) the vacuum line is one at the rear of the intake manifold right next to the distributor and remote coil. I
     think it feeds the cruise control.
  I'll attack it again in the morning.
Don
87 Chevy Silverado
  • Z62 ON-ROAD
« Reply #7 on: March 27, 2009, 09:16:22 am »
OOPS  I was thinking to unplug the vaccum hose to the vaccum advance, but the efi distributor doesn't have it, so you shouldn't disconnect any vaccum hoses for this.
Offline lawdog49
« Reply #8 on: March 27, 2009, 09:29:13 am »
not meaning to thread-jack here, but Chris- what does the IAC look like and where is it- i think i need to do this cause my idle has gotten rough all of a sudden.
1991 GMC Suburban 1500   -   5.7/AT/4x4/TBI
« Reply #9 on: March 27, 2009, 10:26:00 am »
Square 4 wire plug on the throttle body
« Reply #10 on: March 27, 2009, 11:24:57 am »
Passenger side of the TBI looks like a "rocket" with as vile stated a square 4 wire plug.
looks like this:
