Author Topic: Need power window help  (Read 15097 times)
Offline Psyco Diver 69
« on: March 27, 2009, 12:08:24 pm »
I have a 84 GMC and the power windows down work, the drivers side supposly had a new motor in it when I bought it but the window is stuck down a inch and the harness was broke, so I went to the junk yard and grabbed another one and wired it in, now I just get a clicking noise. I have it wired from left to right like this Blue/white, Tan (also has the rod through it), Blue, Brown, Pink, and Black. I broke out my test white and hooked onto the ground and got the pink is a siwtch 12v, brown and blue only light up when I hit the drivers window switch, tan sparks up, and blue/white lights up when I hit the passenger switch. Why does the tan one with the copper rod going through it spark up like its shorting out?
Re: Need power window help
« Reply #1 on: March 28, 2009, 11:27:25 am »
Alright well after some smacking and what not the window will go up but only half way down, I did this a few times, then it stopped half way down, and I can't get it back up, the motor will make that ticking noise again except it will click once and not make any noise for a minute then go back to clicking. BTW the motor sounded loud and crappy as heck, its suppose to be a new motor and looks like it
« Reply #2 on: March 28, 2009, 11:35:07 am »
to tell the truth the motor is getting pretty hot, oh and I just did try jumping the motor with a extra battery, still just clicking
How the heck do I get my window up now, its suppose to rain later
« Reply #3 on: March 28, 2009, 11:50:33 am »
alright I found out if I push down on the window as hard as I can it will move, theres about 2 inches of free play in the window, meaning I can pull it up or push it down 2 inches. Does that mean I regulator is shot?
« Reply #4 on: March 29, 2009, 12:43:35 am »
Definitely check the regulator, tracks, seals and adjustements.
« Reply #5 on: March 29, 2009, 02:10:35 am »
i would agree with vile but it seams to sound like the regulator, on my truck when the regulator went bad you at first could assist the window into doing what you wanted it to do then it would just start clicking like it stripped a gear, replaced it and fixed the problem. while you have it all apart i would think about replacing the motor also since you and the PO prob. put it under a lot of stress and over heated it
Offline musicitymafia
« Reply #6 on: March 29, 2009, 09:22:47 am »
Check your channel seals and make sure nothing has broken off and is putting the window in a bind.  If the channels are good you would be better off replacing the regualtor and the motor all at the same time since both need to come out anyway.  Sounds like the motor is damaged now because of the stress.
1985 Chevy Silverado SWB 305
MPS LEAD THE WAY
Offline GoatBeard
« Reply #7 on: April 01, 2009, 10:12:16 am »
