Author Topic: Water leak  (Read 8281 times)
Offline Stowburb
Water leak
« on: March 27, 2009, 03:56:59 pm »
Hey Guys,
 I am installing OEM carpet in my '91 burb, it had a rubber floor in it and when i removed it i found the floor to be soaked! Best i can tell it is coming from somewhere near where the door hinges bolt to the body.
 Has anyone ran into this? is there a common problem with these trucks? and what can i do to correct it?
Thanks for any help, just dont want my " rustless" truck to rust!
 Chris
Offline oldwhity
Re: Water leak
« Reply #1 on: March 27, 2009, 09:33:34 pm »
Dry everything up and set a sprinkler on the side that is leaking and wait. You should be able to see the water coming in and pinpoint the source of the leak. Good luck.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline justpball
Re: Water leak
« Reply #2 on: May 04, 2009, 12:03:26 pm »
mine is doing the samething on my 2wd...I am going to be looking for mine and if I come up with anything I will post it here...
Re: Water leak
« Reply #3 on: May 04, 2009, 12:56:25 pm »
Look around the windshield and kick panel area. The cowl can back up also.
Re: Water leak
« Reply #4 on: May 04, 2009, 01:15:52 pm »
You may also want to open up the cowl area and see if the seal is rusted.  I did my annual cowl cleanup about 3 weeks ago to get the junk out of there.
