does this look right
Topic: does this look right (Read 15127 times)
Re: does this look right
Reply #15 on:
March 29, 2009, 03:22:13 pm »
You should be able to weld it in place without pulling the engine. The starter bolts are knurled so make sure you are using the correct bolts. Again, make sure it's shimmed correctly and don't over tighten the bolts
Russ130
Reply #16 on:
March 29, 2009, 04:12:27 pm »
You also should be able to helicoil it if need be. I wouldn't use jb weld for anything more than ornamental type stuff. Which bolt pattern starter do you have the diagonal or straight? If you have the straight style bolt pattern you could get a diagonal bolt pattern starter. Are both your starter bolts like the one vile posted? Is one shorter than the other?
weebo74
Reply #17 on:
March 29, 2009, 05:01:29 pm »
ok off what is helicoil and yes both bolts are the long ones and the bolt pattern is diagonal
Reply #18 on:
March 29, 2009, 05:44:34 pm »
Is the hole in the block for the straight pattern also?
A heli coil is a threaded insert you can repair a stripped hole with.
weebo74
Reply #19 on:
March 29, 2009, 06:24:05 pm »
vile the bolt pattern is diagonal and here is some pic's of the hole and the crack sorry if the pic's are small won't let me go bigger
Russ130
Reply #20 on:
March 29, 2009, 07:46:18 pm »
Looks like it has already been helicoiled once, wouldn't hurt to ad another section of coil to it and loctite it in place. That would fix the problem with bolts coming loose. You still have a problem with either the wrong starter or the flywheel is shimmed too much at the crank though. The starter gear while engaged should mesh completely with the flywheel in other words the gear will make contact with the whole tooth on the flywheel not just an 1/8" or so. This very same problem could be what caused your original flywheel to lose some teeth.
weebo74
Reply #21 on:
March 29, 2009, 08:00:12 pm »
thanks russ for the info and the original flywheel was not missing teeth that is what the shop told me all it had was about 8 teeth had flat spots
Reply #22 on:
March 29, 2009, 11:31:58 pm »
maybe some loc tight
weebo74
Reply #23 on:
April 05, 2009, 07:28:33 pm »
well here is a update well took it to a real shop had them weld and helicoil and put some loc tight it the bolt hole and the truck starts fine and runs like a stuck pig thanks for all the info guys
