Author Topic: Temperature Guage Q's  (Read 6822 times)
Offline 79K20
« on: March 30, 2009, 11:21:47 am »
Hey all.
Just trying to diagnose why my temp gauge quit working. Its a '79 K20 w/ 350 eng. I believe it is a vacuum-type temp sensor, right?
Anybody know how these things work? Is there an easy way to test the sensor and the gauge separately to see which is malfunctioning?
Thanks.
Re: Temperature Guage Q's
« Reply #1 on: March 30, 2009, 01:36:24 pm »
No, it's a thermistor. Take the wire off of the sending unit screwed into the drivers side head and ground it with the key on. See if the gauge moves.
Offline 79K20
« Reply #2 on: March 30, 2009, 03:15:35 pm »
I thought the sending unit was on the thermostat housing...?
That blue thing with the four vacuum lines coming out of it...?
Offline JRConnieK10
« Reply #3 on: March 30, 2009, 03:27:09 pm »
Should be on the left side head behind the first spark plug
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
« Reply #4 on: March 30, 2009, 05:19:19 pm »
That's just a thermostatic vacuum switching valve.
Offline 79K20
« Reply #5 on: March 31, 2009, 08:23:25 am »
A What-Ditty-What? Here it comes... What on Earth does a Thermostatic Vacuum Switching Valve do?
Haven't had a chance to ground that sensor wire out. Will do it later today and see if the gauge works....
« Reply #6 on: March 31, 2009, 02:03:52 pm »
When temp goes up it allows vaccum to pass through.
