Author Topic: Help With Either Zing Frame or Notching Crossmember  (Read 35060 times)
Re: Help With Either Zing Frame or Notching Crossmember
« Reply #15 on: April 13, 2009, 11:24:11 am »
The wheel gets uncentered if you use stock suspension and a bag setup with it laying on the ground with a limited amount of lift (riding one low).
The only way to fix this is to move the mounting location forward.  Just Z'ing the suspension will NOT fix this, it only makes it lower.
Offline slimneverdies
« Reply #16 on: May 18, 2009, 11:53:35 am »
Ok, help me understand a little better! Are you guys saying that the silver truck with the Porterbuilt setup would not be decent truck to say pull a trailer with a 85 el camino on it? Im in the process of bagging my 86 C10, not to lay rocker or anything too serious but I still want to be able to tow my el camino from different shops to my garage. Let me know so I'd know if "back to the drawing board" is my next step.
Thanks, Slim
« Reply #17 on: May 21, 2009, 06:06:14 pm »
Slim, call Porterbuilt and talk to Nathan and tell him what you are wanting to do.
Offline blue beast
« Reply #18 on: May 24, 2009, 02:51:39 pm »
dont know if you wanna do this butt ive seen alot of guys z the frame and also cut an inch and a half off the bottom of the frame and box the frame in.have also seen thick wall 2x4 tubing put in the frame rails. 8)
chevy tuned up like a nascar pit stop
Offline aussie
« Reply #19 on: June 14, 2009, 07:22:13 am »
i was thinking of the 1 1/2" notch out of the front crossmember and lowered spindes and springs  would be the cheapest why to go for me, i love the PB fronts but at the moment with the ecomonyits  not a good idea, my only concerns would be if you do notch the front crossmember wouldnt it be wise to also lift the steering box up the same amount ?? would that keep everything inline?? also lifting the steering box maybe the notch could go to 2" just a thought!!
« Reply #20 on: June 14, 2009, 11:33:13 am »
Buy a Porterbuild Drop member and rear section.  The front bolts in so you can reverse it and it will put the truck on the ground, the rear bolts/welds in and will do the same.
http://www.porterbuiltstreetrods.com/ tell him Captkaos sent you.
If you still want more info on the above post back.
Is this the correct link?
« Reply #21 on: June 14, 2009, 12:28:08 pm »
It is the correct link, it appears the site is down...
This is his info:
Address
5338 East Main Street
Mesa, Arizona 85205
Phone
480 326-6303
Email
nathan@porterbuiltstreetrods.com
Offline aussie
« Reply #22 on: June 14, 2009, 04:25:55 pm »
this is his new website??
http://www.dropmember.com
« Reply #23 on: June 15, 2009, 12:16:46 pm »
They must have been down the other day.  Both of those are his websites.
Offline pwtr02ss
« Reply #24 on: August 12, 2009, 04:18:38 pm »
I would raise the cross member or just build a new one out of 2x4 stock. That won't affect it that much and get you on the ground. As for lift and towing concerns..I'd box the frame from under the cab back and include this in your notch. That should be enough. As for lift. I'd throw a 2600# bag on the front with a cup just tall enough to still lay but get the most lift out of the bag
Offline 355shortbed
« Reply #25 on: August 12, 2009, 07:42:39 pm »
my buddy was up telln me that you can cut the bottom of the frame under the cab off and plate it and box it in and it gets you close enuff to eatn rocker and its still just as strong with out all the hassle of going through a traditional BD
