Author Topic: 1973 C10 CARB ISSUE?  (Read 3699 times)
Offline GAROLD26
« on: April 09, 2009, 06:49:37 am »
I HAVE A 1973 CHEVY C10 THAT I CANNOT FIGURE OUT WHAT'S WRONG. IT BOGS DOWN WHEN I TRY TO GIVE IT TOO MUCH GAS. I PUT FUEL LINE CLEANER IN IT, CHANGED THE FUEL PUMP, CLEANED OUT THE LINES AND PUT A NEW FUEL FILTER IN AND IT IS STILL DOING IT. IS THE PROBLEM THE CARB? ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED!!
Offline HAULIN IT
Re: 1973 C10 CARB ISSUE?
« Reply #1 on: April 09, 2009, 07:35:24 am »
Garold, It sounds like the accelerator pump system isn't working. Assuming it's a Q-jet, it's in the Left front corner. You will need a kit to fit it. Tell us what carb it is & we can go from there. Lorne
Offline Just-speed
  • 84K10 350/700r4
« Reply #2 on: April 19, 2009, 07:26:25 am »
Shame there is no update yet.  This would be easy to figure out if you get us a little more info.
Let GM go belly up! I got what I wanted. Thanks for building the best truck ever.
« Reply #3 on: April 19, 2009, 07:29:31 am »
Just use a flat blade screwdriver to depress the accelerator pump while the engine is idling. It should stall the engine. Check for kinked fuel lines also.
