Author Topic: How to identify Long or Short water pump?  (Read 13055 times)
Offline Mike Phillips
« on: April 13, 2009, 07:47:49 am »
Is there a way to identify or measure a water pump to tell if it's the long or short water pump?
There's a complete bracket set-up for a big block chevy on eBay that I want to bid on but it's for the long water pump option.  Motor is a stock 454 out of a 1986 2-wheel drive Suburban.
Offline frogman68
Re: How to identify Long or Short water pump?
« Reply #1 on: April 13, 2009, 07:49:48 am »
If you can stick your hand between the pump and the timing chain cover its long if you cant its short.
Thats my method others might have another idea.
I think you can put the short or long on as long as you compensate at the fan.
« Reply #2 on: April 13, 2009, 09:48:31 am »
If it is from an 86 454, it is long a long pump.
« Reply #3 on: April 13, 2009, 11:12:51 am »
Here's what it looks like,
The eBay auction is almost up, think I'm going to bid on these brackets.  Not sure if these are priced at fair market value though.  Any ideas?  I don't want to use the serpentine system no matter how great it might be, I want to keep my engine simple.
eBay auction
http://tinyurl.com/csanm6
Mike
« Reply #4 on: April 13, 2009, 11:14:37 am »
Just realized the auction says,
a 1971-79 Big Block Chevy Engine
I have a 1986 era Mark IV 454
Guest this means these brackets won't fit the block?
« Reply #5 on: April 13, 2009, 11:32:48 am »
My mechanic friend in Oregon says the brackets should all work fine on my block.  Said I'll have to get a different water pump because of the way the serpentine pump was designed to rotate.
« Reply #6 on: April 13, 2009, 11:36:08 am »
same BBC,  I read you other post, I would use the factory Serpentine setup....
« Reply #7 on: April 13, 2009, 11:37:26 am »
You would have to get a new pump if you are eliminating serpentine.  I would use serpenting over these.  I have V-belts on mine and would switch in a heartbeat.
« Reply #8 on: April 13, 2009, 11:44:34 am »
I appreciate your advice and respect it too, but I am really big into keeping my engine compartment Simple Simon and traditional v-belt system is a better option for my preferences.
« Last Edit: April 13, 2009, 11:50:27 am by Captkaos »
