73-87 Chevy & GMC Trucks
Short box 4x4 frame.....
Topic: Short box 4x4 frame..... (Read 4900 times)
chronos
April 17, 2009, 01:34:19 pm »
Thinking of my project options.
I have a short box 4x4 frame, can I swap over everthing
from my 88 full size Jimmy onto this frame?
What is different between frames?
Thanks
HAULIN IT
Re: Short box 4x4 frame.....
April 17, 2009, 02:15:32 pm »
Chronos, The Blazer frame is 6"-8" shorter than the short bed truck frame in the middle, making the wheelbase different, so it's a no-go. Lorne
choptop
Extended cab fanatic
April 17, 2009, 09:02:32 pm »
Lorne is right. You would have to shorten the frame and relocated the body mounts and even then, I dont think it would work right.
Blazin
Blazin new trails!
April 18, 2009, 07:23:55 am »
Running gear except the rear drive shaft will all bolt in pretty simple. Body will not fit even with the cab mount brackets. Frame is completely different.
April 20, 2009, 03:58:21 pm »
As Blazin stated, the body will not fit, there is nothing simular on the frame except for the portion under your feet forward.
