Performance
85 c10, 305 to 350. Need ECM mods?
Topic: 85 c10, 305 to 350. Need ECM mods? (Read 8422 times)
mwood150
April 17, 2009, 02:45:06 pm »
I have the carbuerated CCC system with MC solenoid. Previous owner replaced the stock 305 with a 350 goodwrench engine. He left all the electronics the same. The truck runs good, but seems very tame. I was wondering if there was something I should do with the ECM and Sensors to make it better suited for a 350? If it matters - all I want is decent power, and I use it primarily for towing a boat.
-Mark
Russ130
Re: 85 c10, 305 to 350. Need ECM mods?
April 17, 2009, 02:56:57 pm »
Unfortunately some 350's are very tame and offer no more power than their 305 conterparts. You could try and swap out the ECM for one out of a 350 equipped 3/4 ton truck. The 3/4 ton would almost certainly have better performance than a 1/2 ton's. I have also heard you can get the chip reprogrammed but I am not positive about that. Just a couple thoughts for you.
mwood150
April 20, 2009, 07:50:31 am »
So then there is a difference in how the 305 ecm and 350 ecm is programmed, but no difference in the sensors? Please someone tell me where I can get a chip or a good deal on a 350 ecm.
April 20, 2009, 11:19:51 pm »
Don't waste your time. If you want to wake it up cheap get a new ignition system and replace your carb. A decent exhaust system will help too.
⌠ŻŻŻŻŻ' [☼===☼]
mwood150
April 21, 2009, 01:43:32 pm »
In other words, do away with the computer stuff alltogether?
mwood150
April 21, 2009, 01:50:13 pm »
If I was to do that, what is a good carb that will bolt up to the stock manifold? I know, most people say this is personal pref, but I dont have personal pref right now.. So whats an all around good performer? Remember, I need to tow, its not a daily driver.
Thanks!
April 21, 2009, 02:25:15 pm »
I would ditch the CCC and put a normal Q-jet on there, it will bolt up to the current setup, minus the control. I would ditch the ESC distributor also.
April 21, 2009, 04:53:22 pm »
Are you good at tuning carbs? The easiest to tune is the edelbrock (carter AFB). The Q-jet can be dialed in nicely also but requires more disassembly.
⌠ŻŻŻŻŻ' [☼===☼]
Stewart G Griffin
April 21, 2009, 08:07:43 pm »
Also, what rear diff gear do you have; That could make a big difference. As far as tame, i was able to turn a 16.8 1/4 mile time last summer with the crate 350(completely stock) and that was with 2.56 rear and cheap off-brand tires(which spun a little). We also have to remember the 3800-4000 curb weight. This was also,as i now suspect, with the engine in sick form (pls see my other pitiful post entitled "new problem" for more info).
mwood150
April 22, 2009, 12:06:18 pm »
My rear diff was 3.08. It could not tow at all whatsoever. I put in a 3.73, and things are much improved. I was just wondering about the computer because that would be an easy upgrade for me if it would make a difference. The guy that had the truck before me spent a good amount getting the carb rebuilt and tuned, so I kinda hate to ditch it right now. As soon as it starts crapping out I will probably go the computerless route.
Performance
