Author Topic: Problem after cab bushing install! HELP!  (Read 6227 times)
Offline tx5.7travel
« on: April 17, 2009, 07:19:10 pm »
Hello Gents! I bought a Prothane Bushing Kit and when I installed the cab mounts, the driver side rear of the cabe was about a half inch lower than the rest making the bed offset (or higher, it does not line up). The driver side came out pretty good. Has any one had this problem, maybe shim the cab or some I did wrong, Please help. Thanks!
Re: Problem after cab bushing install! HELP!
« Reply #1 on: April 18, 2009, 07:06:32 am »
The bushings are all the same size? Sure you didn't get a mismatched one or something? The hole in the frame bracket isn't rusted out?
« Reply #2 on: April 18, 2009, 02:47:46 pm »
Set your tire pressures and measure your trim heights.
Offline levisjohnson
« Reply #3 on: April 18, 2009, 04:09:01 pm »
You might have accidentally put your core support bushings on the back on that one side only.  I am with Vile, if you measure your trim, I bet you will find you put your front is too high.  But that is just my opinion.
Levis
88 6.2L Diesel 3+3 3/4 ton
Offline tx5.7travel
« Reply #4 on: April 18, 2009, 07:04:36 pm »
The bushings where matched up with the old ones before installed. They looked simple to install. I did set the tire pressure and measured the trim from the garage floor to the trim, 29" on the driver's side and 28 1/2" on the passenger side. I noticed that the front passenger side had a shim in it when I removed the old cab bushing? All mounts had a little rust but where in solid shape? I took a visual of the bushing and it look like the rest and not over tightened?
« Reply #5 on: April 18, 2009, 09:23:47 pm »
2wd or 4wd? Now measure your spring hieight and see if you have spring fatigue or a suspension problem
Offline tx5.7travel
« Reply #6 on: April 19, 2009, 03:27:07 pm »
2wd and there are new springs in the front and th rear was good to go?
« Reply #7 on: April 20, 2009, 03:29:27 pm »
Is the floor support/pan rusty?
Measure from the bottom of the frame and leave the suspension out of the mix.  Contrary to popular belief cars don't site 100% level.
Offline tx5.7travel
« Reply #8 on: April 21, 2009, 08:07:21 pm »
That I will try when I return from the sand pit in July. Thanks!
