Author Topic: 10 bolt to 12 bolt swap  (Read 15655 times)
Offline a66boo
« on: April 19, 2009, 01:23:09 am »
I recently acquired a 12 bolt 3.40 gov-loc posi rear from a 1979 1/2 ton shortbed that I want to bolt in my 1985 1/2 ton that has it's original open 10 bolt rear... This leads me to the u-joint dilemma where the original 10 bolt yolk was larger than the 12 bolt.  Does anyone know either the physical measurements for the proper u-joint size that bolts into the 12 bolt so I can try to fins a conversion joint to adapter?  Or better yet happen to know a part number for the conversion u-joint!?
Thanks for your time...
Re: 10 bolt to 12 bolt swap
« Reply #1 on: April 19, 2009, 01:35:33 am »
i don't know any joints numbers but what i did at autozone when i worked there bring both joints or get them to get them from behind the counter and then get them to find a similar joint with two ends that match the size and leanth of the 85 and the other two that match the 79
« Reply #2 on: April 19, 2009, 07:21:49 am »
Offline a66boo
« Reply #3 on: April 19, 2009, 10:09:42 am »
Thanks Guys!!   I searched and searched, apparently I don't search well!
Vile, Thanks a million!!
Offline a66boo
« Reply #4 on: April 20, 2009, 01:34:41 pm »
Just for clarification and assistance to possible future folks searching on this subject.....
The Corporate 10 bolt 8.5 inch rear on my 1985 1/2 ton 4x2 uses a 3R size joint on the drive shaft and yolk.
The 12 bolt from a 1979 1/2 ton 4x2 uses a 1310 size joint on the yolk.
A conversion u-joint would be available: Here's a source
http://www.dennysdriveshaft.com/p466_1310_to_gm_3r_s44_series_combination_u_joint...spicer_grease.html
Or
http://www.theujointstore.com/33131.html
