Author Topic: Power Door Lock Actuators  (Read 21316 times)
Offline AdrianR
  • Big Blue Beastie - '85 Suburban K10, 6.2 diesel
« on: April 21, 2009, 07:08:38 pm »
Folks
This one has me scratching my head.
I have figured the wiring from the door lock actuators, lock/unlock switches ,to the polarity reversing relay. Everything works as it should...when it's hot-wired.
However, my relay has no power and without a schematic (power locks are not shown on the schemas in the forum) its difficult to trace the source. It's a heavyish orange/black cable...
Anyone know where it is fed from?
Chevy lover
1985 Suburban K10 Silverado diesel
Re: Power Door Lock Actuators
« Reply #1 on: April 21, 2009, 07:53:26 pm »
The power windows/locks have a separate harness the gets power from the fuse box, it is also grounded on the side of the cowl.
Offline AdrianR
« Reply #2 on: April 21, 2009, 08:00:17 pm »
My fuse box doesn't seem to have a window/lock marking for a fuse...do you happen to have a fuse layout diagram, Captain? Your help is appreciated.
Chevy lover
Offline ccz145a
« Reply #3 on: April 22, 2009, 08:03:20 am »
I don't think it's fused at the panel, just getting it's power from the panel. This power then goes to the separate harness.
« Reply #4 on: April 22, 2009, 08:12:17 am »
It should plug into fuse block cavity E but you didn't provide any info on your truck.
Click here to view full size
« Reply #5 on: April 22, 2009, 11:10:12 am »
Vile, I copied this to the Wiring diagram post if that is ok.
« Reply #6 on: April 22, 2009, 01:33:36 pm »
That's fine, just resize it.
« Reply #7 on: April 22, 2009, 03:03:44 pm »
I used the original size.
Offline AdrianR
« Reply #8 on: April 22, 2009, 04:50:41 pm »
Thanks for the helps guys - three locks working, one bad actuator (driver side, rear), and I re-sited the polarity-reversal relay as it was in a total pig of a location.
Strangely enough, the window and lock circuits are on separate fuses. Looking at the fuse block, right side topmost fuse (which was unmarked and missing) was for the power locks.
Live and learn...
Chevy lover
« Reply #9 on: April 22, 2009, 08:10:51 pm »
Is this a pickup, 4 door or suburban?
Offline AdrianR
« Reply #10 on: April 23, 2009, 07:52:29 pm »
It's in my sig...
Chevy lover
