Author Topic: foam pads between fender and cab?  (Read 16881 times)
Offline pinheadandy1
« on: April 21, 2009, 09:05:21 pm »
I'm doing a frame off resto on my 78' fleetside (not to be a trailer queen or anything just a "daily driver/fresh and clean" condition type thing). There's these foam pads (one on each side) in between the front fenders and cab that run vertical/parrallel with the front edge of the door. I would presume they are meant to be a seal of some sort or there for noise reduction or something. Any way mine are pretty much done for and need to find something to replace them with. I've searched the forum and every aftermarket company I could find with no luck. Anybody know where I can find them? Maybe im looking in the wrong places? Or do you guys leave them off or make something else work? thanx in advance.
Andy
Re: foam pads between fender and cab?
« Reply #1 on: April 21, 2009, 09:51:52 pm »
Not all trucks had them. I have seen them on a few gas jobs, but almost all the diesels had them. I don't bother with them if they are in that rough of shape.
« Reply #2 on: April 22, 2009, 08:53:51 am »
You mean the fender escutcheon? You can probably find a good set at the junkyard or look in the classifieds section here. I've seen them in restoration catalogs before too.
« Reply #3 on: April 22, 2009, 10:59:09 am »
I don't know of anyone making the foam/rubber sealers for the fender to cowl area.  All diesels got them for engine noise reduction and all Silverados had them.
« Reply #4 on: April 22, 2009, 11:07:43 am »
Every truck I ever had had them unless someone removed them.
« Reply #5 on: April 22, 2009, 11:20:16 am »
All the base model trucks I have gotten didn't have them.
Offline 80stepsideguy
« Reply #6 on: April 22, 2009, 12:08:33 pm »
My 85 cab had them i removed them and chucked them since they were in bad shape. I just welded up the holes and smoothed them out.
thanks
pat
« Last Edit: April 24, 2009, 06:13:22 pm by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
Offline fitz
« Reply #7 on: April 22, 2009, 04:52:09 pm »
I've torn apart a bunch of these trucks(mostly 89-91 blazers/Suburbans), they were ale silverados/SLE's and they all had them. Like Vile said, they should be around in the junkyard.
« Last Edit: April 22, 2009, 04:54:22 pm by fitz »
Offline JRConnieK10
« Reply #8 on: April 22, 2009, 04:54:20 pm »
I've got a set and was debating on using them. Are they worth it?
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
« Reply #9 on: April 22, 2009, 08:03:22 pm »
I think if they're clean and in goodshape they look good, just paint them black.
« Reply #10 on: April 23, 2009, 02:25:35 am »
Any idea which catalogs you've seen them in Vile? Iv looked, but havent found much. Thanx
Andy
Offline bigblock73
  • Yeller
« Reply #11 on: April 23, 2009, 07:43:49 am »
The "pads" we are talking about bolt to each side of the cab, right behind the front fender/door area.  You can see the passenger side one in this pic of my truck
I have seen no reproductions of them in any of my catalogs.  My 73 has them and they were in great shape so I reused them.  I agree with the others, not all trucks had them.
« Last Edit: April 23, 2009, 10:57:53 am by Captkaos »
Jeff
'73 swb 2wd
73-87.com
Offline Just-speed
  • 84K10 350/700r4
« Reply #12 on: April 23, 2009, 07:55:54 am »
Oh ok my bad.  I have never seen them before.   My 84 K10 does not have them.
Let GM go belly up! I got what I wanted. Thanks for building the best truck ever.
« Reply #13 on: April 23, 2009, 07:56:24 am »
I'd have to look to see who has them new but try the dealer first. Does anyone have microfiche for our trucks?
Offline trucknut18
« Reply #14 on: April 23, 2009, 09:51:25 am »
my uncles '80 had them, he took them out and when u drove the truck on the highway u could this annoying wissle sound,,but u probably dont need them, i eliminated the ones on my 81
