Author Topic: 4.1L 2BBL straight 6 ...carb info  (Read 10948 times)
Offline fiyaweed06
« on: April 22, 2009, 11:10:58 pm »
Hello! newbie here trying to find out info on the carb that comes on this engine.I just bought the truck and was trying to find info on how to adjust the carb......Thanks
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: 4.1L 2BBL straight 6 ...carb info
« Reply #1 on: April 23, 2009, 12:08:56 am »
Welcome to the site!
Which year is it?
Offline fiyaweed06
« Reply #2 on: April 23, 2009, 09:57:50 pm »
its a 1982 sierra
« Reply #3 on: April 24, 2009, 11:18:59 am »
What is on it now?
Offline fiyaweed06
« Reply #4 on: April 25, 2009, 12:43:03 am »
its on the engine in the truck everything is still factory.
« Reply #5 on: April 25, 2009, 01:14:30 am »
Year make and model and why your at it the trany. i have one of those engines that came out of a 79 c10 thats just sitting in a barn right now
« Reply #6 on: April 25, 2009, 08:15:58 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5220.0
1979-82 10-30 & 1500-3500 Series With Light Duty Emissions
NOTE: For curb idle speed specifications see; under hood label or Idle Specifications .
NOTE: Vehicles with a Gross Vehicle Weight Rating (GVWR) below 6000 lbs (8500 lbs for California), and passenger carrying vehicles with a capacity of 12 persons or less, are Light Duty Emissions Vehicles.
Fig. 61 - Propane Enrichment Tool Installation
NOTE: Idle mixture adjustment requires artificial propane enrichment using tool-26911 , or equivalent--Fig 61.
NOTE: Air cleaner must remain in place, and A/C control, if equipped, must be in OFF position--except where noted.
Disconnect and plug vacuum hoses as directed by Emission Control Information Label.
Connect tachometer to engine following manufacturer's instructions. Start engine and run at fast idle until it reaches normal operating temperature.
Place transmission in drive (manual transmission in neutral) and adjust curb idle speed to specifications:
On carburetors with a throttle stop solenoid, turn solenoid plunger screw.
On carburetors without a solenoid, and on models with an A/C speed-up solenoid, turn throttle stop screw on carburetor.
Disconnect crankcase ventilation (PCV) tube from air cleaner. insert hose with rubber stopper from propane valve into opening in air cleaner. NOTE: Propane cylinder must be adequately filled and remain upright during adjustment to insure correct propane flow.
Slowly open propane metering valve while observing tachometer. Continue opening valve until engine rpm begins to drop and note maximum enriched rpm.
Fig. 62 - Propane Enrichment Specifications
Fig. 63 - Propane Enrichment Specifications
If enriched rpm is within specifications, Figs. 62 and 63, turn OFF propane flow and proceed to step 15.
If enriched rpm is not within specifications, turn OFF propane flow and remove plugs sealing mixture screws as outlined in Concealment Plug Removal . NOTE: On models with limiter caps, remove limiter cap from each mixture screw, taking care not to damage screws.
Start engine and allow it to reach normal operating temperature.
Turn each mixture screw in (clockwise) until lightly seated, then back screws out equally, just enough so engine will run.
Place transmission in drive (manual transmission in neutral).
Turn mixture screws counter-clockwise equally, 1/8 of a turn at a time, until maximum idle rpm is obtained.
Adjust idle speed to specified enriched rpm, Figs. 62 and 63, following procedure in step 3.
Turn mixture screws clockwise equally, 1/8 of a turn at time, until specified curb idle speed is obtained.
Repeats step 5 then turn OFF propane flow. If enrich rpm is not within specifications, repeat step 10-14.
If equipped with a throttle stop solenoid:
Disconnect wiring harness connector to solenoid.
Adjust low idle speed to specifications with throttle stop screw.
Connect wire to solenoid.
If equipped with an A/C speed-up solenoid:
Disconnect wiring harness connector to A/C compressor and place A/C control in ON position.
Momentarily open throttle to allow solenoid plunger to extend, then adjust A/C idle speed to specifications with solenoid plunger screw.
Turn A/C OFF and connect wiring harness connector to compressor.
Remove enrichment tool an install PCV tube in air cleaner. Connect vacuum hoses to proper fittings.
